Arc Fault Break Tripping When Any Light Switch Turned On - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-15-2009, 05:00 PM   #31
L84DnR's Avatar
Originally Posted by PaliBob View Post
Congratulations on including some history. It sounds like you have started with all the right steps.
When you say everything did you mean just the AFCI breaker? If so there may be an overlooked AFCI protected receptacle that is outside the Bedroom.
Have there been ANY changes in plugged in devices, or lamp bulbs, or any changes at all in your home wiring?
Here is the Square D AFCI Data Sheet. I donít know your brand, but this may
Spark an idea:
http://ecatalog.squared.com/pubs/Cir...0760DB0204.pdf
You will get more suggestions as you continue to respond, but please let us know the outcome because you WILL Find the solution that will help a lot of folks on this forum. Including Me.
But? Obviously, SOME here, BUILDING INSPECTORS EVEN, as well as a few DIY homehandy men, "appear' to be vastly more skill trained than A "mere" Industrial Electrician ((whom graduated WITH HONOURS)) so- go fry yourselves..
I don't care.
All I care about- is the 1st precaution in that PDF that PaliBob submitted... BUT NONE OF YOU READ.
& U do not know- SO
"go" & read it now.
L84DnR is offline   Reply With Quote
Old 07-15-2009, 05:02 PM   #32
L84DnR's Avatar
Precautions:-
DANGER:-
HAZARD OF ELECTRIC SHOCK, EXPLOSION OR ARC FLASH
This document is written for qualified electricians. Other than connecting
and disconnecting receptacle loads, the work described here should be
done only by trained professionals.
Failure to follow these instructions will result in death or
serious injury.
Old 07-15-2009, 05:10 PM   #33
L84DnR's Avatar
Originally Posted by L84DnR View Post
Precautions:-
DANGER:-
serious injury.
READ THE LINE- it says "WILL" KILL"
Not "maybe"
Not "oh - can I tease?
Can I "bypass"?
CAN I DISOBEY ALL SAFETY ADVICE?
The thread starter said a PROTECTION DEVICE FAILED.?
& asked for help.
THE PRECAUTIONS GIVEN WITH THESE UNITS...
specifically say- FIND THE FAULT-
BEFORE RE-POWERING THE CIRCIUIT..
There ARE no 2nd chances... Uv had it.
The protection "tripped".
DO NOT thinK? Oh? I can tease a "sw" (after U were told a fault exists) NOR to "bypass_this" ? with a "piece" of non_protection wire? & Simply being "able" to do an inspection of the building- for "overviews" does NOT imply U know what to look for- UNLESS U are a fully HIGHLY qualified Electrical Inspector, (& even they die- when they "GET IT WRONG").
DO NOT PLAY.
If the device trips. LEAVE THE CIRCUIT DEAD & fault find the CORRECT WAY.
Old 07-15-2009, 05:12 PM   #34
L84DnR's Avatar
But?
Then again- I should have "known" better...
this is NOT an electrician's SITE...
It's a DIY (DEAD_IF_YOU) DO IT YOURSELF - "home" handy man's "UM? site...
Old 07-15-2009, 05:19 PM   #35
You already done with that lightning book?
Here's some more homework; Google the phrase below
define: bombast
Old 07-15-2009, 05:52 PM   #36
L84DnR's Avatar
http://www.ewrb.govt.nz/
Old 07-15-2009, 06:23 PM   #37
L84DnR's Avatar
Originally Posted by Yoyizit View Post
Causes of death
1000/day from smoking
250/day from hospitals
160/day from guns
110/day die on the highways
14/day from food poisoning
4/day from electrocutions
170/yr from CO poisoning
55/yr from lightning
1 injury in 50 yrs from a meterorite
Here's some homework for ya', Mr. R
http://www.probability.ca/sbl/
As to house fires, dividing your fire insurance premium by the replacement value of your house will approximate the likelihood of a house fire for any reason, per year.
It should be impossible to tease a good switch; there is a built-in snap action, the effect being the same as what hysteresis gives you.
P.s
U "forgot" the 100% death rate- at the END of any "life".
So it does NOT matter what statistic U throw at me-?
If U die - (as a result of ELECTRICAL INCOMPETENCE)
It's a 100% fatality RATE.
Plus? I suppose U do HAVE "fire" insurence?
Which simply means ths...
Ur RISK is actually HIGHER than mine.
I have ZERO insurance... thus ZERO risk.
& finally...
U ARE WRONG... as it does NOT MATTER ... if you use an OLD sw or circuit breaker, NEW sw or circuit breaker...
IF U tease a "sw" ("precisely")...
IT IS POSSIBLE with ANY "switch" to create a delay_crossover function ... & thus an ARC (however minor)
The SNAP action- to which U refer- is the one the CIRCUIT BREAKER USES... & even "these" (NEW) can ARC severely... which is WHY they are specifically "built" with "extremely_efficient" (ANTI_ARC) suppression_chambers...
THEY ARC.
Old 07-15-2009, 06:39 PM   #38
Learning by Doing
Leah Frances's Avatar
Sometimes I feel like I talk to much. Guess not.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-15-2009, 06:45 PM   #39
L84DnR's Avatar
;-) ok POINT NOTED..
I'm login off...
Old 07-15-2009, 07:00 PM   #40
Learning by Doing
Someone owes me a dollar.
Old 07-15-2009, 08:33 PM   #41
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Assuming nothing has been changed the odds are he has a neutral fault that is common to all lights on that branch circuit. Likely in the switch box where power is brought first then onward to the other switches and lights. But could be in a receptacle box if power went to the switches and lights from it. He could narrow things down a tad if he removed light bulbs then tried the switches to see when the neutral fault showed itself with only one fixture with bulbs installed.
As for all the conversation from our friend in NZ ..120 volt single phase branch circuits do not react the same to arc flash as large switch gear in high voltage cabinets. It's like comparing apples to mangoes... or is it oranges...
RCD's cannot be compared to AFCI's. They can be compared to GFCI breakers to the extent of protecting one branch circuit. An RCD protects several branch circuits. Afci's if installed since 2005 are combination devices that detect both series and parallel arcs of the bad kind. Duration has a big play in a good and bad arc and current flow at the arc.. RCD's do not detect arcs. They only detect loss of current equalization between conductors in the branch circuit. Arcs do not always display themselves with minute current leakages to ground or neutral and therefore will not be detected by a RCD or GFCI which is our similar protective device.
Rather than me giving one of my famous always clear as mud dissertations I would suggest googling 'combination afci'. And spend some time reading. Square d offers a 'free' 10 minute training on afci if you want to order the product at no cost. They were sending it via e-mail but I'm not sure now what they do.
BTW the afci is very controversial at this time as most of us know and is not yet widely accepted by local jurisdictions, though more and more are requiring them.
For those interested here is a basic explaination of the combination afci now mandated by the national electrical code in the USA.
http://www.squared.com/us/products/c...n-Feb%2008.pdf
Unfortunately the OP seems to have vanished so we may never know if he revealed the whole stroy or not...nor will we find out the solution.....
Thanks Leah........
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 07-15-2009, 08:53 PM   #42
Learning by Doing
Stubbie - As for all the conversation from our friend in NZ ..120 volt single phase branch circuits do not react the same to arc flash as large switch gear in high voltage cabinets. It's like comparing apples to mangoes... or is it oranges...
KIWIS
Oh stop me, or I'll go too far....
Old 07-16-2009, 12:35 AM   #43
" Euro " electrician
frenchelectrican's Avatar
Stubbie.,
Let me expand with the RCD due you know I do work both USA and France system { yeah I go back and forth both places}
The older RCD are nortius for tripping due very poor design sorta simauir to the early generation GFCI were way back early to mid 70's if you recall that.
Now speed the time warp to modern time most RCD's are not really capabaile to fuction like AFCI but few do detect arc fault but at diffrent setting than what the North American verison is.
And yes the RCD do come in single , double and YES the triphase verison as well.
Merci,Marc
Old 07-31-2009, 01:40 PM   #44
Question
Arch fault devise
Great forum, I am a woman sculptor and specialize in custom chandelier art, I am a UL certified engineer for luminairs. Recently a designer client emailed me with a bill (6 months after work was done and a year after fixtures were installed)for an electrician who switched out sockets on several of my fixtures claiming they were causing the new Arch fault devise to trip, the sockets, were brand new UL listed high quality Leviton, tested in my shop three times for shorts, damage and Hi-pot tested as well, fixtures passed. After emailing back and forth the electrician says the fixture worked fine but the light bulbs were not staying screwed in the socket "due to thermal shrinkage" which I find to be silly as I have been using these sockets for 10 years,
My UL inpector advised me to not pay the bill but get the old sockets back from client and send to manufacturer for a claim, client said work was dome months ago (they did not call me then of course) and sockets were gone. I do not feel resposible for the $1200 bill as this soulds like a faulty devise? Client is very upset and wants to pass the buck to me but even though they are a good client, I was not given a chance to inspect fixtures myself or even trouble shoot over the phone and I stand by the high quality of my work, paying would admit my fixtures were at fault.
what do you guys think?
Any help would be greatly apprciated
bodner is offline   Reply With Quote
Old 07-31-2009, 02:26 PM   #45
http://www.google.com/search?client=...UTF-8&oe=UTF-8
http://www.google.com/search?hl=en&c..._nhi=&safe=off
So is the Burden of Proof on you or them?
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
GFCI light switch trips once per night ???? mw6263 Electrical 11 07-25-2008 11:05 AM
New light switch burns out dsbutler71 Electrical 12 09-05-2007 07:34 PM
