Aquapex Plumbing In Proximity To Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2008, 03:11 PM   #1
Aquapex Plumbing in proximity to electrical
In our remodel, the plumber has run Aquapex Plumbing through the new bathroom ceiling near the area where I had planned to install a Nutone Heater/Vent combo. Is this going to be a problem?
Besides the obvious of water not mixing with electricity, what other code issues am I looking at. How can I make this a safer installation?
Randell Tarin is offline   Reply With Quote
Old 03-18-2008, 03:53 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
I am unclear as to how this is "unsafe". I am also curious as to how water and electricity are "mixing".
Old 03-18-2008, 04:04 PM   #3
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
Maybe you could get the plumber to run the water in the fan to disperse the water at different rates. Something like ranging from a water sprinkler system to fight a fire to a light mist to cool off in.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 03-18-2008, 04:09 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
love jcalvin's answer.
there is no code violation (at least electrical) from what you posted. As long as the pipe does not leak, there is no concern with anything getting wet.
It's like a roof; as long as it works right, nothing gets wet and all is well in Electronville.
If this has not been installed yet, be sure your are to install you vent is clear and open so you do not have to mess with the water lines and there is no chance of you accidentally making a hole in the water lines.
Old 03-18-2008, 04:10 PM   #5
There not. However, if a leak should ever occur, however unlikely, water could potentially mix with electricity. Just want a safe, permanent installation.
I'm putting up beaded ceiling panels and I don't want to ever have to rip this out to do repairs.
Old 03-18-2008, 04:18 PM   #6
This could be said about MANY areas in a home. It is impossible to avoid such interaction.
I think you are looking for, or assuming there will be, a problem where none exists, due to the close proximity.
Then make sure your Pex guy knows what he is doing.
Old 03-18-2008, 04:21 PM   #7
Thanks fellas!
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 08:55 PM
Electrical and Plumbing Nightmare KenTheHandyMan Electrical 5 10-01-2006 05:33 PM
New home plumbing cost wdsfr1968 Plumbing 7 07-28-2006 09:41 AM
