Appropriate Junction Box For Exposed Knob And Tube - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 11:06 PM   #1
Appropriate junction box for exposed Knob and Tube
Hey guys, my rental was recently inspected and the inspector pointed out a hot knob and tube line in the attic that was basically just hanging in space. Obviously this has to be secured, and he recommended I pickup a junction box to secure it in and he will re-inspect it in a month.
What type of junction box should I use? Plastic, metal, fiberglass? Does it matter? I have plenty of old plastic wall boxes..would these suffice if I put a cover on them? Also, what should I wrap the exposed end in? standard wire nuts? If there is a hot line exposed, can it go in the same box using a different wire nut?
Obviously I don't want a fire hazard (more than what k&t is already) but $6,000 to rewire isn't in the cards right now.
Thanks for your help guys!
quaker87 is offline   Reply With Quote
Old 02-14-2013, 11:14 PM   #2
Electrical Enthusiast
Rewards Points: 504
I find it surprising that an unused line would be left live. Can you post some photos?
If it really is a random live wire, you can pretty much use any box, just make sure the wire is protected. (Metal boxes require bushings/clamps in the knockouts). You can put wire nuts on the end of the wires and put a cover on the box.
As always, make sure you turn off the fuse/breaker feeding it before you do anything.
Kyle_in_rure is offline   Reply With Quote
Old 02-14-2013, 11:18 PM   #3
thanks for responding kyle. I will be over there again tomorrow as I have another electrician coming in to give me a price on upgrading the wiring and I will take a picture...
Old 02-14-2013, 11:24 PM   #4
Rewards Points: 504
You may want to check my post again, when I first responded I misread your post, so I had to edit.
Old 02-15-2013, 08:27 AM   #5
Licensed electrician
Rewards Points: 996
You could also cut it off at the last junction point.
Old 02-15-2013, 09:32 AM   #6
joed's Avatar
Rewards Points: 11,516
I would trace the wire back and cut it off at the nearest junction.
The Following User Says Thank You to joed For This Useful Post:
NJMarine (02-15-2013)
Decommissioning Knob and Tube Perry401 Electrical 7 05-14-2014 11:04 PM
question about replacing knob and tube ocelli77 Electrical 2 11-24-2012 08:30 AM
Replace old Knob and Tube with Romex stevefrench Electrical 13 10-04-2012 07:59 AM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 01:17 PM
Was splicing to knob and tube outside a junction box ever legal? WillK Electrical 6 01-26-2011 01:50 PM
