Appliance Wiring Material - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2007, 03:42 AM   #1
hi
can i use a # 6 awm stranded type wire from a main panel to a sub panel in conduit under ground? it will have 40 amps or less on it. this is what it says on the wire. awm mil 6awg/133 fep 600v 200c from what i read online i think its silicon based its oily when you touch it . this might be a unusual way to use this wire but with the price of copper if will work it will save me money
thanks??
apeman76 is offline   Reply With Quote
Old 08-10-2007, 07:20 AM   #2
Agent 000
SecretSquirrel's Avatar
#6 wire is rated for 60 amps so putting it under a 40 amp breaker poses no problems at all. You are putting it under a 40 amp breaker aren't you?
SecretSquirrel is offline   Reply With Quote
Old 08-10-2007, 07:33 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
To put it in pipe, under ground, it must be rated for use in a wet area.
Old 08-10-2007, 01:38 PM   #4
im using a 50 amp breaker. i just wanted some comments on the wire type to make sure there was no problem using that type off wire thanks
Old 08-10-2007, 01:51 PM   #5
Agent 000
Don't ignore jbfan's advice
Old 08-10-2007, 01:54 PM   #6
ok thanks for the help
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Issues with appliance plug hgiljr Electrical 1 03-17-2007 08:09 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
