Appliance Cord & Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 08:08 PM   #1
Rewards Points: 512
appliance cord & plug
I'm waiting on Dishwasher and Disposal appliances to come in and am wondering if they come w/ cord and plug, or if I need to purchase those separately. I've already installed the receptacle for them, which is a 20a split receptacle; DW always hot, disposal switched.
If I need to buy these cords, I'm assuming that the plug will need to be attached by me, since the hole in the cabinet won't be large enough to fit a plug.
Old 05-27-2012, 08:10 PM   #2
Licensed electrician
Rewards Points: 1,474
Make sure the cords are listed for use on the appliances.
You could cut a larger hole in the cabinet.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Code05 (05-27-2012), sirsparksalot (05-27-2012)
Old 05-27-2012, 08:22 PM   #3
Code05's Avatar
Rewards Points: 1,104
What Jim said and I have not seen either of those items pre-wired with a cord.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
Old 05-27-2012, 08:27 PM   #4
Rewards Points: 582
most dw are hard wired....some disposals have cords....not all...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 05-27-2012, 08:45 PM   #5
Rewards Points: 512
hmm, thought I read somewhere that cord and plug was preferable.
Old 05-27-2012, 08:45 PM   #6
Code05's Avatar
In the past yes, but now you need a local disconnect, so not so much any more.
Never saw a pre-wired disposal, but lots of stuff I have not seen.
Old 05-27-2012, 08:45 PM   #7
Rewards Points: 512
Old 05-27-2012, 08:48 PM   #8
Rewards Points: 512
OK, so I still need to know where to get these. Are they simple appliance cords (like microwave) available at the Orange Store, or will I need to get them at an appliance store?
Old 05-27-2012, 08:55 PM   #9
kevinp22's Avatar
you should be able to get what you need at the orange store
kevinp22 is offline   Reply With Quote
Old 05-27-2012, 08:57 PM   #10
firehawkmph's Avatar
Rewards Points: 1,864
Sirs,
you can get them at the box stores. Pretty straight forward. Whenever I install kitchen cabinets, I drill holes in the sink base for the dw cord (1 1/4"), drain hose (1 1/4"), and water supply line (3/4"). The hole for the drain hose is up high, the cord hole midway up, and the water supply closer to the cabinet floor. All are in the rear of the side wall of the cabinet, about an inch from the back panel.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 05-27-2012, 09:00 PM   #11
Code05's Avatar
Yes, but note the appliance must listed for a cord and the cord must be listed for the appliance.
Old 05-27-2012, 09:13 PM   #12
Rewards Points: 512
Gotcha, Code. If the appliance requires hard-wired, then I'll do that.
Old 05-27-2012, 10:15 PM   #13
Idiot Emeritus
Rewards Points: 1,492
The small hole in the cabinet shouldn't be an issue. The cord will come with a plug on one end, and nothing on the other. Just put the bare end through the hole first.....
Rob
micromind is offline   Reply With Quote
Old 05-27-2012, 10:20 PM   #14
Master Electrician
don't forget the disconnect, although some inspectors count a plug as a means of disconnect most that i have met prefer a hard wired dw.
i should clarify that the quoted text was quoted because it's a point that needs be remembered, not because there's anything wrong with it, don't want to get yelled at
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
run spliced lamp cord inside a wall? denemante Electrical 20 12-17-2010 09:35 PM
240 v Space heater plug? CooperChloe Electrical 12 02-04-2009 10:57 PM
GFI Plug Troubleshooting bryanchr Electrical 4 08-22-2008 05:28 PM
Is it safe to plug in this flourescent fixture? doofalot Electrical 2 08-16-2008 01:27 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
