It Appears To Be A Ceramic Capacitor But... - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2009, 07:38 PM   #1
Question
It appears to be a ceramic capacitor but...
I am trying to find a replacement for what appears to be a ceramic capacitor. However, after trying the numbers on the component in google, I have had no luck at finding an identical or equivalent component.
Apparently there is some kind of identification convention for ceramic capacitors, but the markings on the component don't seem to follow the convention.
So I am not sure what to do from here. Is this not a ceramic capacitor, or is there another way to read the markings on the component?
kimbokasteniv is offline   Reply With Quote
Old 06-05-2009, 07:51 PM   #2
DIYer
If I had to guess, 14 picofarad 10%.
Gigs is offline   Reply With Quote
Old 06-05-2009, 07:57 PM   #3
Rewards Points: 2,350
On the circuit board where this component was located, was it labeled? Like C12, or some such? If so it is a capacitor. I have also seen MOVs that look like this.
Old 06-05-2009, 08:03 PM   #4
DIYer
Yes, that was my thought as well, it could be an MOV.
Old 06-05-2009, 08:05 PM   #5
140 pf would be my guess
hayewe farm is offline   Reply With Quote
Old 06-05-2009, 08:33 PM   #6
Thanks for all of the replies you guys.
It is labeled as VR1. And it belongs to the circuit board of a DeWalt battery charger.
Old 06-05-2009, 08:51 PM   #7
Hmmm... VR would either be "variable resistor", or "voltage regulator". It certainly isn't a variable resistor. I'm not sure if a two-pin regulator exists, or can exist. Well, I take that back. A zener diode is sort of like a two-pin shunt regulator. Could this be some sort of shunt regulator?
Old 06-05-2009, 09:06 PM   #8
DIYer
Inphase VR is probably:
http://en.wikipedia.org/wiki/Varistor
Look at the picture on that article... I think that's it... so it's an MOV.
Oh and the good news is you don't have to replace it to make the thing work. The bad news is that replacing it won't make your thing work if it's not working now.
Old 06-05-2009, 09:14 PM   #9
Yeah, it didn't dawn on me that VR might mean "varistor". I was thinking of "varable resistor" as in potentiometer, which it certainly isn't
Old 06-05-2009, 09:38 PM   #10
Alright, that seems to be it.
I had actually stumbled upon that wiki article after searching around about MOVs after you and InPhase suggested it. However, after reading the article I had the impression that I could replace the component with just a wire to test whether the rest of the board was operational.
But I guess you are suggesting that the amount of power required to cause damage to this component would surely damage some other components on the board.
Whatever the case may be, I'll replace the component with a wire, just for laughs.
Thanks for the help everyone.
Old 06-05-2009, 10:11 PM   #11
DIYer
Don't replace the MOV with a wire! It will short out.
The MOV does not conduct normally. What I was saying is that the circuit should work fine with the MOV missing. If it doesn't then you have other problems.
Old 06-05-2009, 10:33 PM   #12
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
MOV= metal oxide VARISTOR. Is not varistor another term for "variable resistor" although it is not a vairable resistor in terms of how I think of a VR?
It would control voltage by bleeding off voltage in excess of its rating or allow current if its rating is exceeded.
just a guess but I would suspect it would allow for an output voltage regulation as the battery is charged. Or, it could simple be a trigger for the led's control as the battery voltage increases, it would allow current to the led to light or inversely to turn off an led.
anybody have a schematic of the charger in question?
and depending on what the MOV is used for, it could cause an overcharge of the battery and subsequent fire is this is a voltage regulator as suggested above. I would not run the thing until its' use is determined.
Old 06-05-2009, 10:55 PM   #13
Yes, see my comments in post #9.
Old 06-05-2009, 11:19 PM   #14
nap
You talking to me?
nap's Avatar
yes, but I was also addressing your point on voltage regulation as well.
Old 06-05-2009, 11:37 PM   #15
Lol, well I guess that's what I get for rushing something involving electricity.
Anyway, it didn't short immediately. Like you suspected another component was broken (just the fuse), so it didn't short until after I circumvented that.
Didn't trip the breaker, but the trace on the board vaporized. Fortunately it was just the trace between the fuse and the MOV.
So, I took your suggestion and left things open were the MOV used to be and the unit appears to work fine now. Although it is outputting 28 volts for a 14.4 volt battery, but that may be normal.
Anyway, I guess I am off to get a fuse and somehow find someone who sells an equivalent MOV.
Problem solved. This is the second time the people on this forum have successfully identified the problem I was experiencing -- doesn't get much better than that.
Thanks for the help.
DuraCeramic over Ceramic tile? SueC Flooring 10 03-17-2011 11:07 PM
Dura Ceramic vs. other kitchen floor options wendysl Flooring 3 02-14-2009 06:41 AM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 09:01 AM
ceramic over basement concrete ponch37300 Flooring 5 11-14-2008 12:42 PM
