Apartment Electrical System Overloaded? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2009, 10:55 AM   #1
Apartment electrical system overloaded?
I have a small sealed oil heater in my apartment to help out the main AC/heating system.
Last week it fried the connector strip and the socket had a scorch mark.
The apt was built in 1972 and the circuit breakers sometimes blow when I plug in an additional appliance (at least they are working).
So it looks like the system is close to being overloaded.
I have an electrician coming in but I was wondering what kind of questions I should be asking. Does the place need to be rewired and is this really expensive?
Thanks - p
ph3iron is offline   Reply With Quote
Old 02-04-2009, 11:05 AM   #2
Not sure about rewire, but at least lighten the loads. What type of wiring do you have? Aluminum? Copper? What brand circuit breakers and panel do you have? What is the capacity of the circuit panels and service?
rgsgww is offline   Reply With Quote
Old 02-04-2009, 11:06 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Are you renting this place? If you are renting, then it is up to the landlord to take care of any problems you have. A heater should never be used on a power strip!!!
jbfan is online now   Reply With Quote
Old 02-04-2009, 11:21 AM   #4
Forgot to mention, if you are renting, its not your responsibility.
Old 02-04-2009, 01:52 PM   #5
Apt overloaded?
Thanks for the replies - I own the place (its at the beach) and will find out the answers tomorrow.
Thanks a lot - p
Old 02-04-2009, 02:11 PM   #6
joed's Avatar
Rewards Points: 12,362
A heater should be plugged directly into the wall not into a power strip or extention cord.
Old 02-04-2009, 02:22 PM   #7
You said 1972, and the wall plug burned up? I suspect aluminum wiring. Maybe devices not co/alr or co/al.
Panel could be fpe, or zinsco with the burn ups.
Old 02-04-2009, 02:36 PM   #8
Yes, thanks - I'd just started plugging it into a strip so found out the hard way
Old 02-04-2009, 04:16 PM   #9
If the plug pulls out easily the contact force is too low and will cause local heating of the socket at heavy current draws.
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 05:24 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
No/little heat on 3rd floor apt collar Plumbing 3 12-06-2008 07:17 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
