Old 10-04-2009, 07:50 PM   #1
Anything wrong with putting an electrical box in a kitchen cupboard
Is it OK to have an outlet on the bottom of an upper kitchen cupboard with the box inside the cupboard? I want to use it to power under cabinet lighting. Thanks
beech is offline   Reply With Quote
Old 10-04-2009, 08:12 PM   #2
.....Yes
220/221 is offline   Reply With Quote
Old 10-04-2009, 09:17 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Sure. This is done all the time for over-the-range microwaves.
Just don't pull power from the counter receptacles. That is expressly forbidden by code.
Old 10-04-2009, 10:09 PM   #4
thank you
Old 10-04-2009, 10:28 PM   #5
Electrical Contractor
kbsparky's Avatar
Originally Posted by Speedy Petey View Post
...Just don't pull power from the counter receptacles. That is expressly forbidden by code.
I have to disagree with you on this. IF the receptacle is mounted under the cabinet, and is within reach of the counter-top, it must be on a SA circuit.
It is not forbidden to plug an under cabinet light into any SA outlet, only if it is direct-wired does the Code have any say-so on which circuit it should or should not be connected to.
-KB
Old 10-04-2009, 10:36 PM   #6
What is a SA circuit/outlet - GFCI protected?
Old 10-04-2009, 10:38 PM   #7
Xtreme DIY'r
Isn't any receptacle within x inches above the countertop required to be on the SA circuit ? Barring dedicated circuits for MW/hood etc
SA = small appliance
Found it....
However it looks like I can install a 15A circuit for a TV above 5 1/2 feet? See 210.52, specifcally "in addition to any receptacle that is: (4) Located more than 1.7m (5 1/2ft) above the floor" 210.52(B) seems to apply to "counter top" outlets.
Old 10-04-2009, 10:41 PM   #8
I installed the outlet to power my low voltage undercabinet lights in the wall / back of the short cabinets above the combo microwave / cooktop hood.
Old 10-05-2009, 06:24 AM   #9
I see I was wrong. I guess I misread the OP. Hence my comment about OTR micros.
I thought they want to install this receptacle IN the upper cabinet, not under it.
I retract my previous comment.
Kitchen island help Bob Sacamano Kitchen & Bath Remodeling 3 12-16-2008 06:38 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
got rid of kitchen island, how to get rid of the electrical wire from floor ckcrew Electrical 15 12-14-2006 10:45 AM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
