-   -   Anything wrong with putting an electrical box in a kitchen cupboard (http://www.diychatroom.com/f18/anything-wrong-putting-electrical-box-kitchen-cupboard-54425/)
beech 10-04-2009 07:50 PM
Is it OK to have an outlet on the bottom of an upper kitchen cupboard with the box inside the cupboard? I want to use it to power under cabinet lighting. Thanks
220/221 10-04-2009 08:12 PM
.....Yes
Speedy Petey 10-04-2009 09:17 PM
Sure. This is done all the time for over-the-range microwaves.
Just don't pull power from the counter receptacles. That is expressly forbidden by code.
beech 10-04-2009 10:09 PM
thank you
kbsparky 10-04-2009 10:28 PM
Originally Posted by Speedy Petey (Post 336429)
...Just don't pull power from the counter receptacles. That is expressly forbidden by code.
I have to disagree with you on this. IF the receptacle is mounted under the cabinet, and is within reach of the counter-top, it must be on a SA circuit.
It is not forbidden to plug an under cabinet light into any SA outlet, only if it is direct-wired does the Code have any say-so on which circuit it should or should not be connected to.
vsheetz 10-04-2009 10:36 PM
What is a SA circuit/outlet - GFCI protected?
Scuba_Dave 10-04-2009 10:38 PM
Isn't any receptacle within x inches above the countertop required to be on the SA circuit ? Barring dedicated circuits for MW/hood etc
SA = small appliance
Found it....
However it looks like I can install a 15A circuit for a TV above 5 1/2 feet? See 210.52, specifcally "in addition to any receptacle that is: (4) Located more than 1.7m (5 1/2ft) above the floor" 210.52(B) seems to apply to "counter top" outlets.
vsheetz 10-04-2009 10:41 PM
I installed the outlet to power my low voltage undercabinet lights in the wall / back of the short cabinets above the combo microwave / cooktop hood.
Speedy Petey 10-05-2009 06:24 AM
I see I was wrong. I guess I misread the OP. Hence my comment about OTR micros.
I thought they want to install this receptacle IN the upper cabinet, not under it.
I retract my previous comment. :whistling2:
