Anyone Know If This Is 3 Phase? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 11:05 PM   #16
www.prosperitees.org
Originally Posted by kbsparky View Post
NOW we are getting somewhere. Are there any other panels in there? You could have a 3 phase main service outside, but only single phase available inside.
No there are only 2 panels . 1 outside and 1 inside. I dont know if this makes a difference but the building consists of 3 units each having the same setup. The owner of this place doesnt even know what type of electrical service he has to his units.
Prosperi-Tees is offline   Reply With Quote
Old 07-10-2011, 11:11 PM   #17
Electrical Contractor
kbsparky's Avatar
See if you can get some pix of each panel with its cover removed.
I'd be willing to bet you only have single phase available inside of your unit, and one of the lugs in the main outside breaker is not being used.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Prosperi-Tees (07-12-2011)
Old 07-10-2011, 11:13 PM   #18
I will try to do that tomorrow when I go to the shop.
Old 07-10-2011, 11:22 PM   #19
Idiot Emeritus
Rewards Points: 1,492
Not so fast. That load center looks like a single phase panel. THAT in and of itself points to a delta-connected service. Let's see if the OP can supply more photos, and information as to the number and location of any other panels present.
You're right, I missed that.
That is indeed a single phase panel. Either two legs of a wye or a delta without the high leg.
The meter is definitely 3 phase though. Being one of the new-fangled electronic ones, there might not be a way to tell what voltage it operates at.
Some of these meters will have a small display that says 120 or 240. This one might, but I can't read it because of the glare.
If it says 120, then it's a 120/208 wye. If it says 240, then it's a 120/240 delta.
micromind is offline   Reply With Quote
Old 07-11-2011, 06:04 AM   #20
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
Ahhh, I never noticed the panel label diagram.
Good catch.
Old 07-11-2011, 07:03 AM   #21
Rewards Points: 1,536
Can you measure the voltage fro m hot to hot and from hot to neutral?
For a high leg (delta) 240 volt system all the 120 volt loads and 120/240 volt loads (of all 3 apartment units here) have to be taken from the same pair of hot legs (usually the A and C legs) and only 240 volt only loads can use the B leg.
For 208 volt system you cannot run 120/240 volt equipment that is not 120/208 volt rated; you could run any 120 volt equipment and some 240 volt only equipment.
Old 07-11-2011, 02:34 PM   #22
kbsparky's Avatar
Good catch.
Yeah, also it should be pointed out that GE does not make any 3 phase panels that accept the THQP (read: TANDEM) breakers, so any panel with them installed is by default a single phase panel.
GE 3 phase panels either accept THQL or THQB breakers. And that is just the cheap ones.
-KB
frenchelectrican (07-11-2011)
Old 07-11-2011, 11:17 PM   #23
inside panel
Old 07-11-2011, 11:18 PM   #24
inside panel 2
Old 07-11-2011, 11:19 PM   #25
outside panels
Old 07-11-2011, 11:19 PM   #26
Outside meter
Old 07-11-2011, 11:36 PM   #27
" Euro " electrician
frenchelectrican's Avatar
I will step in here.,
Your inside load centres are single phase panels they are NOT triphase panel at all.
For the outdoor main disconnect switch that is a toss up I am not sure if you have actually a delta or wye hook up unless you look at the meter socket and see the voltage on the display screen it should say either 120 or 240 volts if 240 then you have delta if say 120 good chance you may have wye service.
So take a photo of outdoor main breaker itself just open the cover but do not remove the inside panel cover off { of the outdoor main breaker box } we can able indentify it pretty quick.
And the last step here due if this is a commercal place you should stop right there and get a legit electrician to assist you on this one.
Merci,
Marc
Old 07-11-2011, 11:46 PM   #28
Merci,
Marc
I will definitely get a legit electrician but I wanted to know before so that I know what type of equipment to look for.
The Following User Says Thank You to Prosperi-Tees For This Useful Post:
Old 07-11-2011, 11:55 PM   #29
You may want ask your electrician to change one of the single phase panel to three phase panel { if your landlord allow it } but as I mention before and few other guys mention as well I have a huntch you have delta system in there due you only have single phase inside panel while you have three phase main breaker so I will give you a 50/50 chance that you do have delta system that one reason why whomever did set up the panel use the single phase panel so that way someone can not make magic smoke on wild leg that one part why.
On legit delta panels you will see every other breaker skipped they do that on purpose { a electrician will expain to you when they confirm that is delta } if wye they should done it long time ago run full boat { all phases } in there.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 07-12-2011, 06:49 AM   #30
You have shown the breaker panel for one of the three apartment units. What do the inside panels in the other two units look like?
Three phase transformer question rongaudier Electrical 8 03-08-2011 07:19 AM
Converting 3 phase equipment to single phase /VFD? lightison Electrical 7 01-04-2011 03:14 PM
Wiring Single Phase through 3 Phase socket tonyr417 Electrical 10 10-26-2010 09:09 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 03:46 PM
120/208/1 phase wiring questions JohnJon Electrical 11 08-31-2008 11:28 PM
