| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Wire a Switch for an Outdoor Fan
by eHow.com
If you want to install an outdoor fan, you should wire a nearby switch so you can control it easily. There are various types of switches that you can use, but what matters most is that you are using components that are safe for outdoor use. Read More »
How to Change Your House's Windows
by eHow.com
If you have old, aluminum frame windows in your home, you might be feeling the winter chill more severely. Swap out your windows for more modern ones and enjoy a cozy winter. Read on to learn more. Read More »
Fire Safety Codes & Fire Department Inspections
by Expert Village
If you are a small business owner and you’re about to get your annual fire safety inspection, it’s a good idea to check all of your exits and make sure that they are clear of debris. Check your extinguishers. Make sure they are not covered up... Read More »
Basement Remodeling: Applications & Permits
by Expert Village
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. In most cities, you'll be required to pull a permit, when finishing your basement. If you maintain open communications, with the city, they'll be able to... Read More »
Fencing Codes
by Expert Village
On behalf of Expert Village, I'm Terry, and I'm here to tell you today about building a wrought iron fence. Before you start any project, it's always helpful to know what your codes are for the city or the county, whatever the governing body is, what... Read More »
