Anyone Heard Of COMMERCIAL ELECTRIC Tools? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-02-2008, 09:46 AM   #16
Advice worth 2 cents!
Rewards Points: 150
While were on the subject...
Has anyone seen my 35 year-old pair of red 8" Klein dikes? Damn-it! it's been like two weeks now.
- pete
Klein,T&B, Ideal, Greenlee,...each one has it's strong and week points.
---pete
HandyPete is offline   Reply With Quote
Old 04-02-2008, 12:45 PM   #17
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
The Chinese are really good at making junk that looks just like a quality item. Inferior steel and heat treating look pretty much the same as high quality. It's when you use them that you find the difference. I use my tools to make money. It would be foolish and short sighted to buy junk in my opinion.
Have you moved the 10 foot step ladder yet? Put your hard hat on first.
jrclen is offline   Reply With Quote
Old 04-02-2008, 05:49 PM   #18
I blame ProWallGuy
Rewards Points: 150
- pete
Right here....
Oh wait, you said Klein Dikes, not Klondike. My bad.
Double A is offline   Reply With Quote
Old 04-02-2008, 08:01 PM   #19
to vital ce tools at hd
stick with kline I dont want to look at made in china when working
joed1234 is offline   Reply With Quote
Old 08-30-2010, 06:57 PM   #20
MCM
Commercial Electric Okayish
I work for Home Depot and can attest to the fact that CE is a far inferior brand to one like Klein. However, they do have their place. I purchased an 11 piece set on clearance for $9(originally $35) for about $60 worth of CE tools, the deal aside the tools work and will be fine for my DIY/friends projects . I plan to replace with Klein when I see what I really use, I haven't seen any difference in the key hole saws yet, but the Klein multi head drivers are well worth the $10 or $12. My Klein strippers that I already owned, definitely feel more natural in my hand. The 22-piece set for $60 is popular with the Tech school crowd, I think that is a fine place to start before you even know that you will earn any money as an electrician. I knew where the CE tools where made, but I too pissed when I saw that the "china" sticker is engraved.
MCM is offline   Reply With Quote
Old 01-12-2011, 07:40 PM   #21
CE tools not all that bad
It am a facility manager and I have bought CE tools for use in our facility. I have a lot of volunteers that help on projects, so I don't feel all that bad when a tool walks off. Most of my personal lectrical tools are Greenlee. I think they are great! I do have Kleins, but the Greenlee just feel better. Hope this helps.
JodyBS2 is offline   Reply With Quote
Old 01-13-2011, 01:13 PM   #22
Rewards Points: 130
The OP mentioned having a backup set of tools. In this case I say go for it. Also, Klein is not what they used to be. I know plenty electricians that have given up on Klein for one reason of the other. Ever tried to "break in" a pair of Klein side cutters (linesman's)? Not easy is it. It can take months.
While 90% of all my electrical tools are Klein, I plan to look elsewhere in the future. Especially for screw drivers. Klein screw drivers have really gone down big time. They don't last long at all. It would be foolish to not at least try what all the other trades guys are now using in place of Klein.
Old 01-13-2011, 03:38 PM   #23
Electrical Contractor
jbfan's Avatar
Rewards Points: 424
And this post is almost 4 years old.
I would hope they have made up their mind about what tools to buy!!!!!
The Following User Says Thank You to jbfan For This Useful Post:
J. V. (01-14-2011)
Old 01-14-2011, 06:44 AM   #24
Lowes in Atlanta is carrying Knipex. As good or better than Klein and nooooooo break in.
AndyinAtl is offline   Reply With Quote
Old 01-14-2011, 06:50 AM   #25
Rewards Points: 756
About 5 minutes with some WD-40 and some fine sand will loosen up a new set of Kleins.
Mark
busman is offline   Reply With Quote
Old 01-14-2011, 10:48 AM   #26
Rewards Points: 130
I have been using Klein's for 35 years. The only way to break them in is to work with them until. Until Until and Until. I have tried everything under the sun and nothing works but use and time. You got some magic sand or something. I am asking?
Old 01-14-2011, 01:40 PM   #27
Rewards Points: 756
I spray the joint with WD-40 and then dip them in very fine play sand (like for sand-boxes). It gets into the joint and loosens it up like sandpaper would. Really, it works, but takes 5-15 minutes of working the tool open-closed to work.
Mark
Old 08-07-2011, 12:29 AM   #28
Rewards Points: 866
Waring
I just picked up a small digital multimeter at Home Depot; a Commercial Electric MS8232B that I told the guy I wanted to be capable of testing Air Con capacitors. I still haven't figured out if they will, but they have a setting for Ohms or CAP that seems to measure nF, which I take to be nano farads.
Anyway I do not see where it says China on the meter. It may on the packaging, but as for quality control I would have liked to have been able to see the back of the meter before buying. Above the prominent verbage about avoiding electrical shock when replacing the two AAA batteries, in much larger case it reads "WARING". The goofs didn't realize there was an "N" in warning!
Klawman is offline   Reply With Quote
Old 08-07-2011, 06:49 AM   #29
I=E/R
a7ecorsair's Avatar
nano farad is a very small capacitor, so does the instruction sheet list the scale ranges? Most capacitors will have their value stamped on them somewhere.
a7ecorsair is offline   Reply With Quote
Old 08-07-2011, 12:52 PM   #30
Rewards Points: 866
It was supposed to have a users manual but none was included and neiter was there an instruction sheet. It automaticaly scaled from nF to F when I used it this morning. Similarly, when reading ohms it begins with MΩ and quickly scales to KΩ or down to Ω.
I measured my dual capacitor and start capacitor. The Fan side of the dual read 10.41 F. but the Hermes side was a mere 1.91 nF. The start capacitor was even worse; 0.19 nF. I havenn't been able to read the ratings on them, yet, but I may have found my problem.
European 220v Tools use with US 220v Outlet dominator Electrical 20 08-02-2012 11:21 PM
new electric water heater - Vacuum breaker necessary? J187 Plumbing 12 05-26-2012 08:42 AM
Commercial Ballast for Residential ???? lanyard_loop Electrical 4 11-11-2008 01:52 PM
Value of used tools Texasguy Building & Construction 6 06-02-2007 11:03 AM
Bought tools today, good or bad deal? Mr. Michael Tools 3 02-13-2007 12:39 PM
