Anyone Have A Schematic Of An Old Gas Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 07:35 PM   #1
anyone have a schematic of an old gas heater
I have an old gas garage heater that came with the house I just bought. Fan comes on, pilot stays lit, but no fire up on the main burner.
Bought a new valve assembly, didn't help. The brand name is "Utility" by "Zero-Climate Manufacturing", probably from the '50s.
Anyone have a schematic? THanks
normbrand is offline   Reply With Quote
Old 08-10-2010, 09:55 PM   #2
I=E/R
a7ecorsair's Avatar
Your new valve didn't contain a diagram? There has to be some way to control temperature. This control is what opens the main valve. Is there a dial on the valve or is there a place to connect a thermostat?
a7ecorsair is offline   Reply With Quote
Old 08-10-2010, 11:12 PM   #3
Rewards Points: 81
Bad thermocouple?
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
Old 08-11-2010, 11:51 AM   #4
bad thermocouple
I replaced it along with the valve. So, I assume it is ok.
Old 08-11-2010, 11:55 AM   #5
The schematic that came with it was so badly destroyed couldn't read it. If I turn the valve to pilot, ( it is a manual light) it stays lit, then when I turn the vavle to on, no action. Also, the wires were messed up a bit. That is why I was wondering if anyone had a schematic of a similar unit I could go by. Thanks
Old 08-11-2010, 09:56 PM   #6
I=E/R
a7ecorsair's Avatar
Sounds normal. Once in the ON position, it is up to what ever controls the temperature to "pick" the gas valve. This new gas valve has wires?? Sure sounds like it needs a 24v transformer and a thermostat. Any chance you could take a picture of the valve and wires?
Old 08-11-2010, 10:11 PM   #7
I=E/R
a7ecorsair's Avatar
Here's a basic thermostat circuit. Not sure what you have but this may help you understand the gas valve.
The Following User Says Thank You to a7ecorsair For This Useful Post:
normbrand (08-12-2010)
Old 08-12-2010, 09:11 AM   #8
Thanks!! That helps for the wall unit to the xformer!
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 07:31 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
