Any Way To Make 220v Work On 110 Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 10:41 AM   #1
Any way to make 220v work on 110 outlet?
Hey guys,
I am a complete idiot when it comes to electrical. I am in the automotive field....
I have this lift that requires 220v
http://www.harborfreight.com/6000-lb...ift-91315.html
10/14amp under load
I don't have a 220 outlet in my garage. Is there any way I can make it work with 110 outlet? Can I use a transformer or do I have to result in installing a 220 outlet in the garage.
thanks!
jyhuh is offline   Reply With Quote
Old 02-27-2013, 10:53 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Welcome to DIY....
'IF' the motor can be rewired for 120Vac....you might be able to make it work....but your problem is total power. Assuming 14a for 240Vac operation, if you want it to work off 120Vac (and assuming the motor can be wired for 120Vac), then you would need 28A at 120Vac...that is heavy 120Vac load.
Even if you could wire the motor for 120Vac, non of your outlets are going to have that kind of supply...at best your going to get 20A out of your outlets. And, no, you can't put a 30A breaker on one of your 20A ckts...that is how fires are started.
Additionally, I really doubt your going to be able to reconfigure that motor for 120Vac operation. At 14A, I really doubt 120Vac is an option....
I would suggest calling an electrical contractor to come out to your place and look at what you have. There is a good chance he might be able to wire up a 240Vac ckt for you with what you have....assuming you have a sub-panel to work with and it has 240Vac going to it.
Old 02-27-2013, 10:57 AM   #3
thanks for your reply. a lot of lifts in this range actually run off 120v so I thought it would be possible. o well
Old 02-27-2013, 11:00 AM   #4
JOATMON
ddawg16's Avatar
Have a look at the motor name plate and see if it shows specs for 120Vac....
But I sort of doubt it....once you get over 20A @ 120Vac....it's usually a lot cheaper and easier to go 240Vac.
Old 02-27-2013, 11:10 AM   #5
No specs, but the manual does say this:
"IMPORTANT! A 220V / 50-60 Hz, 12 FLA / Duty Cycle: 5 min, 2 HP / Single Phase, Dedicated 20A circuit is required. It also requires a single phase, 3-prong 250V/20A (NEMA L6-20P) power plug (not included).
THIS WIRING PROCEDURE MUST ONLY BE DONE BY A QUALIFIED, CERTIFIED ELECTRICIAN!"
my laundry room is right next to the garage. there is a 3 prong outlet for my dryer, would that work?
Old 02-27-2013, 11:31 AM   #6
JOATMON
ddawg16's Avatar
If it's an electric dryer....yes....you 'could' use that.....but be for warned....taping into that outlet and using the same ckt for both the dryer and your lift might be against code....hopefully one of the experts will chime in...
Is it done? All the time from what I've seen.....is it right? I wouldn't do it....I'd run a dedicated ckt....
Look on the positive side...run a dedicated ckt and you could also use it for a welder....unplug the lift...plug in the welder....
You really should get an electrician out there.
The Following User Says Thank You to ddawg16 For This Useful Post:
jyhuh (02-27-2013)
Old 02-27-2013, 11:43 AM   #7
ok thanks. I was just planning to plug in and unplug the lift when not in use. any danger in just using that outlet with the lift plugged in?
I've heard that the dryer outlet is 30amps?
Old 02-27-2013, 11:51 AM   #8
JOATMON
ddawg16's Avatar
As long as only one is plugged in at a time....you will be fine....like I said, you wouldn't be the first to do it...
So....what kind of project car are you working on to need a lift?
Old 02-27-2013, 11:58 AM   #9
I'm quitting my job as a service manager of a big retail mechanic shop. i am spoiled and used to working on cars on lifts, can't go back to laying on my back, did that the other day to flush out coolant and it wasn't fun. dont have a project car, but I thought it'd be a good investment since I have 3 vehicles and do my own work
Old 02-27-2013, 02:33 PM   #10
An old Tradesmen
Rewards Points: 7,412
Moved to electrical forum.
how do I make the last outlet switched? dancram Electrical 5 10-26-2011 09:30 PM
220v circuit - one outlet only? hippodrome Electrical 20 10-19-2011 09:09 AM
de-activate 220v electric stove outlet 6fthook Electrical 17 10-04-2011 06:32 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
