Any Way To Do This To Code? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 11:57 AM   #1
Rewards Points: 83
I have just finished our kitchen remodel and got a great deal on some in cabinet lights. We have cabinets with windows in the doors and when running the new electrical I planned for this and installed outlets behind each of the cabinets (with access panels).
So now my problem is that the lights plug in to an outlet with a little wall wart thing (not to big but noticeable) and so I have this transformer sitting right in the middle of the inside of my cabinet (remember they have windows so you can see it when the doors are closed. Also I have no way to turn them on or off other than unplug them from the outlet.
My question is I would like to hard wire this and put it all in the electrical box and I have been looking at some various wireless switches to turn them on or off. I could not find anything in the electrical codes about what you can stuff in to these outlet boxes (obviously I would have to remove the outlet).
How is this normally done?
linuxrunner is offline   Reply With Quote
Old 11-29-2010, 01:26 PM   #2
joed's Avatar
Rewards Points: 13,286
since the fixture has plug you need a receptacle to plug it in. Can't think of a code compliant way to do this.
The switching could be done using a combo device with a switch and a receptacle in one device. Then at least you wouldn't need to unplug it everytime.
Old 11-29-2010, 02:15 PM   #3
Licensed electrician
Rewards Points: 1,746
A more conventional method would have been to install switch controlled receptacles above the cabinets or use hard-wired cabinet lights.
Modifying the lights would violate the UL listing and should not be done.
Can you fish a cable to a location for the switch?
Old 11-29-2010, 04:41 PM   #4
Rewards Points: 83
Yeah, i guess i could but i wanted 3 seprate switches for each set of cabnets (3 diffrent sets on diffrent walls of the kitchen). And given we have just finnished painting and trim after 4 months of work I am not looking forward to ripping 3 big holes in the wall to run wire for switches.
Joed,
Thanks that looks like it may be my best option if i don't want to do some wire pulls. Now to convince the wife
When we wired i tried to make sure i thought of everything ... Can't believe i didn't think of switches
Old 11-29-2010, 04:50 PM   #5
You might be able to get addressable receptacles and install a programable switch. Lutron or X-10 might have something.
Old 11-29-2010, 06:25 PM   #6
joed's Avatar
Could you replace the fixture with some that have switches built into them?
Old 11-29-2010, 07:22 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
X-10 would be my choice. Install x-10 super sockets in the cabinet boxes and place a x-10 controller on the counter. You could get 3 super scokets and a mini-controller for under $35 including shipping on eBay.
http://cgi.ebay.com/THREE-PACK-X10-S...item255cd8ac87
http://cgi.ebay.com/X-10-X10-MC10A-M...item5d2343b9b0
I have bought from this vendor many times and they are very reliable.
Coastal South Carolina
Old 11-29-2010, 09:16 PM   #8
I, too, think X-10 or similar (insteon, UPB, Z-wave, etc.) is an ideal solution to the control problems. This does not solve the visual issue with the transformer, however.
The nice thing about this is that you can get a timer/controller. How nice are lights that come on by themselves! I think that is cool, at least.
oberkc is offline   Reply With Quote
Need advice; GC's ignorance of code to cost us extra? Merst Off Topic 9 06-12-2010 09:22 AM
frigidaire oven/range trouble code F1 Pete Sloniker Appliances 0 12-12-2009 07:28 PM
code details for boxes kama Electrical 6 01-30-2009 10:25 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
