-   -   Any special considerations installing lights/wiring with I-Joists? (http://www.diychatroom.com/f18/any-special-considerations-installing-lights-wiring-i-joists-113479/)
tigereye 08-09-2011 10:21 AM
Buying a new house that has engineered/I-Joists. I want to replace the existing cheapo basement porcelain fixtures with some banks of fluorescents.
Just wondering if there are any special rules for engineered joists? I understand the rules about going through the joist and/or not cutting/notching the bottom plate. Specifically, I just wanted to make sure there are no special concerns with stapling when running along the joists and/or hanging lights from the bottom plate?
Thanks,
Mike
Daniel Holzman 08-09-2011 11:13 AM
The I joist manufacturer typically stamps the I joist. The manufacturer usually has a set of instructions on allowable penetrations, fasteners, and methods for hanging fixtures. Check the manufacturer's website, or call them if they don't have the specs.
electures 08-09-2011 06:26 PM
As stated earlier, the I-Joists are pre stamped. You just need to pop the plugs out and run the wiring through the holes. Stapling along the joists is not a problem either.
tigereye 08-10-2011 08:13 PM
Thanks, guys, I'll check with the manufacturer for instructions.
Mike
