Any Slim/Half-Sized Arc Fault Circuit Interupters (AFCI) Yet? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 09:31 AM   #1
Any Slim/Half-Sized Arc Fault Circuit Interupters (AFCI) yet?
Are there any Slim/Half-Sized AFCIs available in type BR. I didn't think to check before I started. I have two circuits and only one (full-sized) space for it.
ppeetteerr is offline   Reply With Quote
Old 04-18-2013, 10:11 AM   #2
Electrical Contractor
kbsparky's Avatar
Not likely. Those things are full of circuitry and as such, need all the space they can get.
Another reason to avoid any panels which depend on those half-pint breakers to provide maximum circuit capacity.
-KB
Old 04-18-2013, 10:32 AM   #3
If I replace the panel do I need to add afci circuits to the upstairs circuits? I'll call the code office when I've got time but I'll be on hold there longer than a response takes here.
The other option is that there is a GFCI circuit in the mechanical room (only powers there and one outlet in the garage) that I could run the bathroom GFCI to. The bathroom is on the other side of the wall and the lights in the bathroom are powered off of another circuit so the amount of streaking that would be involved would be minimal. I'm not crazy about it but it tempts me.
There's a couple of things in the house that make me wish I had a time machine to go back and slap the contractor. I'm just trying to make it so the next owner doesn't want to go back 10 years and slap me around.
Old 04-18-2013, 01:54 PM   #4
Rewards Points: 31
You can just get tandum breakers for other circuits to make room for two arc fault breakers. Just be sure to pay attention to shared neutrals. You don't want to take two circuits that are sharing a neutral and put them on the same bus, you'll overload the neutral.
htae is offline   Reply With Quote
Old 04-18-2013, 02:02 PM   #5
Unfortunately, the panel I have has 12 spaces and 24 circuits. Which means the AFCI breakers eat up spaces rather quickly.
Old 04-18-2013, 02:12 PM   #6
Rewards Points: 31
Arc fault is only required for bedroom receptacles, so if that's what these circuits are for then yes, you will need them. How many receptacles in total? I would combine them if it's 12 or less and then you only need one breaker
Old 04-18-2013, 02:16 PM   #7
Philly Master's Avatar
Rewards Points: 516
ACFI's are for ALL CIRCUITS .... unless your on 2005 code ... less the kitchen, or 2 pole breakers ...
most of the inspectors ... will allow a panel replacement without requiring ACFI's ....but if you add anything then that will need to be ACFI ...if needed
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 04-18-2013, 02:27 PM   #8
Rewards Points: 31
Where are you located ppertteerr?
So, does this mean that there are no shared neutrals anymore?
Old 04-18-2013, 02:31 PM   #9
Rewards Points: 516
Correct
Old 04-18-2013, 02:37 PM   #10
Rewards Points: 31
What about lighting and inductive loads?
Do you have a code reference?
Old 04-18-2013, 02:42 PM   #11
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
There are 2 pole AFCI's if you have MWBC that need to be protected with AFCI and it may help to check with your local code enforcement office. Maybe areas are not requiring AFCI's for panel changes.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-18-2013, 02:46 PM   #12
I'm in Salt Lake Utah. The last time I spoke with the code office I was told I needed AFCI's for new work in bedrooms but not in living rooms, dens, etc... I guess I could combine them. Although it would be more than I like. I have 12 receptacles on one circuit and 3 (plus 4 9 watt lights) on another.
Old 04-18-2013, 02:48 PM   #13
rrolleston's Avatar
Eventually everything in the house will require AFCI including kitchen. And dishwashers and washing machines will have to also be on GFCI. I can see the need for a breaker that does GFCI and AFCI with this new code coming out. But it may be a while for many towns to adopt the new code. I have not even had to deal with any AFCI breakers at all yet in my area.
Old 04-18-2013, 03:22 PM   #14
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Not true for the 2008 or 2011 editions of the NEC.
Correct
Not correct. There are no codes eliminating MWBC. It is true they would have to be on a 2P breaker, but these are being produced by some manufacturers today. You could also feed a AFCI receptacle assuming you meet the requirements to use an AFCI receptacle.
Old 04-18-2013, 04:27 PM   #15
Rewards Points: 516
"ACFI's are for ALL CIRCUITS .... unless your on 2005 code ... less the kitchen, or 2 pole breakers ..."
should have read .....
ACFI's are for ALL CIRCUITS .... less the kitchen, or 2 pole breakers ...unless your on 2005 code ....
Arc Fault vs Ground Fault. JetFuelBurner Electrical 3 11-05-2011 02:36 PM
A few wiring questions (GFCI, AFCI, 2011 NEC) mudworm Electrical 7 10-10-2011 07:32 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Loose electrical outlets travishume Electrical 30 08-01-2008 07:21 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
