Any Safe Way To Wire A Fixture Using Metal Clad To Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 03:20 PM   #1
Newbie willing to work
Rewards Points: 32
Any safe way to wire a fixture using metal clad to romex
I am redoing the insulation in my attic and came a cross a patch made by the previous owner.
There is metal clad wiring to an old ceiling fixture. The previous owner was no longer using that fixture. But he connected Romex to the old ceiling box and ran Romex to the new ceiling fixture. Inside the old ceiling box, he pigtailed the hot and neutral and screwed the ground wire to the box. The old box was no longer fastened to anything and the box was not covered. I assume it is common to add new wiring but isn't there something better than this??
Thanks.
FileOpen is offline   Reply With Quote
Old 11-28-2011, 06:21 PM   #2
Msradell's Avatar
Rewards Points: 90
The box definitely needs a cover put on it and it needs to be attached someplace in your attic that will remain accessible after you have the new insulation put in. Any splice needs to be accessible, they cannot be buried.
Msradell is online now   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
FileOpen (09-20-2012)
Old 11-28-2011, 06:26 PM   #3
joed's Avatar
Rewards Points: 11,588
Screw the box to a joist or rafter and install a cover. It can be buried in insulation if you wish.
The Following User Says Thank You to joed For This Useful Post:
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 10:03 PM
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 12:33 PM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 03:37 PM
Is it safe to plug in this flourescent fixture? doofalot Electrical 2 08-16-2008 02:27 PM
