Any Rule Against Putting A Panel On The Inside Of An Exterior Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 09:54 PM   #1
any rule against putting a panel on the inside of an exterior wall?
Please be gentle... I'm a noob.
I've been trying to find out if I can move my electical panel to the inside of an exterior wall. It's currently on an interior wall, and I figured I'd ask before I really did something stupid.
thanks
graysqwrl is offline   Reply With Quote
Old 07-13-2011, 09:59 PM   #2
I=E/R
a7ecorsair's Avatar
thanks
How far from the meter will it be? Do you know if there is a disconnect between the meter and the panel as it is currently configured?
a7ecorsair is offline   Reply With Quote
Old 07-13-2011, 10:10 PM   #3
I believe there's a disconnect at the meter where the drop is. (what happens if there isn't?)
My property has two units with separate meters. Both meters are located behind the guest house.
I'm guessing the distance from current location to the meter is 60' give or take
If I moved it to the inside of the back exterior wall that would make it about 50' from the meter.
Old 07-13-2011, 10:23 PM   #4
I=E/R
a7ecorsair's Avatar
It makes a difference if they are service conductors (unfused) or feeders but since we now know the meter is on another structure and there is a disconnect, they are most likely feeders.
The panel can be on the inside of an exterior wall.
Old 07-13-2011, 10:25 PM   #5
I=E/R
a7ecorsair's Avatar
BTW, why do you want to move them? It will be a lot of work moving all the circuits.
Old 07-13-2011, 10:32 PM   #6
Just checked... there is definitely a service disconnect at the meter
Old 07-13-2011, 10:34 PM   #7
I bought the house a couple of years ago and it just had screw in fuses (home built in 1905). At the time, I had a panel installed and a new drop and just said... eh... put it wherever.
It took me a couple of years to put together a floor plan and now I have 1/4th the house down to the joists and studs. Time for the rest of the knob and tube to go... but my wife's new kitchen layout calls for the panel to be moved to a different location so she can have her granite peninsula.
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 02:05 PM
Putting in a new electrial fuse panel? imola ghost Electrical 9 09-04-2008 11:39 AM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 12:20 PM
