Any Rule Against Putting Monitoring Devices In A Circuit Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2014, 01:17 PM   #1
Any rule against putting monitoring devices in a circuit breaker?
I am trying to build a monitoring device for the circuit breaker. Does anyone know if this is against codes or what codes I would need to follow?
Student42 is offline   Reply With Quote
Old 01-28-2014, 01:39 PM   #2
Licensed electrician
Rewards Points: 1,634
Breakers are a listed device. You are going to need to have your modified assembly test in order to be listed and this will not be cheap. What or why are you trying to monitor the breaker?
gregzoll (01-30-2014)
Old 01-28-2014, 01:40 PM   #3
Master Electrician
Rewards Points: 3,874
How would you put such a device "in" a circuit breaker without altering it? That would be a violation. Investigate using a current transformer attached to the conductor coming from the circuit breaker.
brric is offline   Reply With Quote
Old 01-28-2014, 01:57 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
ABB, Siemens, GE and Eaton all make monitored circuit breakers. Are you re-inventing the wheel?
The Following 3 Users Say Thank You to Maintenance 6 For This Useful Post:
gregzoll (01-30-2014), Know A Little (01-28-2014), Speedy Petey (01-28-2014)
Old 01-28-2014, 02:48 PM   #5
Apparently there are. But. . .since this is a DIY site. . .
You could put a Microswitch that actuates when the breaker handle flips and then lights a bulb
or
wire a 10mA LED and diode and dropping resistor from one side of the breaker to the other. If the breaker opens the 120v causes DC current through the LED light.
Wear level 2 arc-flash gear and other PPE if you're going to remove the panel cover.
A photocell system would be even less intrusive, or small magnets on the breaker handles that operate reed switches with battery current.
Old 01-28-2014, 02:51 PM   #6
Jim Port what do you mean by a list devise? Or modified assembly test? What codes should I be looking at for this?
Old 01-28-2014, 03:48 PM   #7
Most electrical parts are tested by a lab like UL to make sure they perform as designed. When you open a sealed unit or modify it it is no longer a listed part and cannot be used. It would again need to be tested. UL has a book called the White Book.
Old 01-28-2014, 07:11 PM   #8
Rewards Points: 826
Originally Posted by Yoyizit
Apparently there are. But. . .since this is a DIY site. . . You could put a Microswitch that actuates when the breaker handle flips and then lights a bulb or wire a 10mA LED and diode and dropping resistor from one side of the breaker to the other. If the breaker opens the 120v causes DC current through the LED light. Wear level 2 arc-flash gear and other PPE if you're going to remove the panel cover. A photocell system would be even less intrusive, or small magnets on the breaker handles that operate reed switches with battery current.
I wouldn't encourage this DIY site or not. Many requirements when you commingle low voltage and household power circuits. 600V insulation, UL approval, and isolation barriers. This is on top of tampering with a UL listed breaker rendering it "unlisted". There are safer ways to learn about electricity than experimenting like this.
curiousB is offline   Reply With Quote
Old 01-28-2014, 07:57 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
First off what is a monitoring device, or more clearly, what is the device you are inventing?
Second, which is "the" circuit breaker you are referring to?
Old 01-29-2014, 08:06 PM   #10
Chewy - Lic. Electrician
You can have the electrical inspector inspect an unlisted device or fixture on the spot and approve it to be installed.
SGC622 is offline   Reply With Quote
Old 01-30-2014, 08:12 AM   #11
Really, what would they look for for approval. Are there any up standards or code or is it just rule of thumb kinda thing
Old 01-30-2014, 09:44 AM   #12
seansy59's Avatar
Rewards Points: 258
This really depends on "what you are doing" to the breaker.
If you are putting a surface mount item on it (maybe something that measures the EMF around the unit) or connecting a unit after the breaker before heading to the load, I really don't see any issues (just make sure the "unit" and wiring is able to withhold the full load rating of the breaker feeding it) You really aren't modifying anything, you're just adding onto it...but it won't affect its operation because it trips internally...
But, If you are looking at disassembling a breaker, modifying it, or the panel, then yes, it automatically voids the UL listing...which can be dangerous especially because of the fire risk due to it's a safety device...and honestly, the breakers are designed so compact, you can't really modify it without breaking open the mold...
It's almost like trying to modify the airbag in your car...dangerous, and you want it to deploy reliably if you need it...same with a breaker, you need that to trip reliably. Buy something that does what you are looking for, that has been through 1,000's of tests for defects/faults, and you'll never have to look back at it again...
seansy59 is offline   Reply With Quote
Old 01-30-2014, 11:14 PM   #13
Rewards Points: 314
A simpler way to do this might be to put some device on that circuit that would alarm at the loss of power. A cheap emergency lighting device, or the cheapest UPS you can find might be an easier way than messing with the breaker. A UPS will still set off its alarm when power is lost, and in your application you would not plug anything into its output.
ChuckF. is online now   Reply With Quote
Old 01-31-2014, 11:18 AM   #14
Rewards Points: 808
Anything you install has to be listed for the purpose. Again, what are you installing, and what do you mean by "monitoring device?" There are people here attempting to help you, but you are being vague.
IslandGuy is offline   Reply With Quote
Circuit breaker not returning everything to power after switched back on sam112 Electrical 7 02-10-2013 12:48 AM
New wiring tripping breaker on another circuit? Kinggofg Electrical 11 04-26-2012 01:36 AM
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 09:45 PM
Can't get the master circuit breaker properly seated davefoc Electrical 1 03-22-2010 06:17 AM
Circuit Breaker, working in reverse dcwestcott Electrical 4 04-06-2009 03:03 PM
