Any Motor Can Replaced Emerson Motor C63CXSCT-3842 - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 04:47 PM   #1
Any motor can replaced Emerson motor C63CXSCT-3842
My restaurant hood system use this motor which broken last month. Only find one in Canada,too much cost for the shipping.now I looking for the other band of motor can replace it,3/4hp,rpm1725,sf1.25,v115/208-230,hz60,ph1,code J,A11.4/5.7,sfa12.6/6.3,amb40,class B.
I bought one Leeson motor before,very similar ,but it overheat after running 10 second ,than start smoking,I try 3times,the motor still work.
I just find out Emerson motor 4115 is similar ,can it replaced the old one???
Flyraw is offline   Reply With Quote
Old 03-13-2013, 06:42 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 528
Any motor that matches those specs will work.
jbfan is online now   Reply With Quote
Old 03-13-2013, 09:52 PM   #3
Idiot Emeritus
Rewards Points: 1,492
Look for a frame size. It could easily be 56 or 56H. If so, any manufacturers similar frame size will fit. If it's 56HZ, it has a 7/8" shaft instead of a 5/8". a 56 frame will fit where a 56H was, a 56H will very likely fit where a 56 was. The 56H is a bit longer, and it has holes drilled to match 56 frames as well as another set of holes further back.
Since you're having trouble with motors, I'd use a 1HP model. It sounds like the 3/4HP is overloaded.
Also, there are two common kinds of cooling. ODP (Open Drip Proof) and TEFC (Totally Enclosed Fan Cooled). The TEFC ones have a cooling fan on the back, the ODP one have a cooling fan inside.
Make sure the fan turns the right way. Most fans will still move air if they're backward, but they'll overload the motor.
Finally, make sure the motor is connected for the correct voltage.
Rob
micromind is offline   Reply With Quote
Old 03-13-2013, 11:09 PM   #4
Rob
Thanks,the frame size is 56,do you means I can use 1HP motor instead?
That motor I bought,it don't running on low voltage,and on high voltage the fan was turn on right way,only one things different is the AMP is 11.0/5.4,the old one is 11.4/5.7,is it the reason cause it overload?
Old 03-14-2013, 10:59 AM   #5
Rewards Points: 204
Frame size, voltage and speed need to be the same. Watch the "C" dimension as the new motor could be longer and not fit.
Blower motor: Emerson to GE threeonesix HVAC 12 08-25-2011 03:59 PM
