Any Issue With Long Run Between Relay And Lights? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-03-2012, 07:01 PM   #16
Originally Posted by Missouri Bound View Post
That won't shorten the runs. You still have to run the power to the relay first, no matter where it is. Different relay points will just be stopping points for the circuit. And you need to run the hot, neutral and ground wires together anyway.
Sure it would. Let's say you have three relays. Run one power to the group, and three control lines. From the relays, then you can have short runs to the target circuits.
(h/t ddawg16)
Of course, if you need separate breakers for those targets, then this plan wouldn't work.
gstein67 is offline   Reply With Quote
Old 10-03-2012, 07:07 PM   #17
Missouri Bound's Avatar
(h/t ddawg16)
I understand that you will eliminate the switch legs...but that's all. Draw it out. If you eliminate the relays from that circuit, you have the same wiring....again, minus the switch legs.....right? It basically eliminates all the switch legs. It adds up, of course, but I doubt it will be a significant amount.
Do you want it your way or the right way?
Old 10-03-2012, 10:41 PM   #18
Another thing to figure out is to home run all low volt switch legs. Then, later on, you could automate the house via computer . I would go with 18/3 bell wire
sparkyjake is offline   Reply With Quote
Cant get flasher relay to function on my motorcycle nickmg555 Electrical 7 02-18-2012 08:04 AM
power surge with 120v relay astetson Electrical 8 01-16-2012 10:46 PM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 08:35 PM
newbie...relay problems jfabes Electrical 11 05-06-2008 04:48 PM
