Any Electricians? Question About A DC Switch. Switch Is On Ground Wire(s). - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-06-2012, 05:06 PM   #16
dmxtothemax's Avatar
Rewards Points: 5,098
What is this switch for ?
Do you really need it ?
Every computor I have seen
has only a mains switch
never have I seen one in DC circuit !
dmxtothemax is offline   Reply With Quote
Old 01-06-2012, 06:55 PM   #17
joed's Avatar
Rewards Points: 11,614
You will run into problem turning off the power to a hard rive and leaving the data lines connected. At least that has been my experience when do PC troubleshooting.
The Following User Says Thank You to joed For This Useful Post:
mpoulton (01-06-2012)
Old 01-06-2012, 11:54 PM   #18
Semi-Pro Electro-Geek
Rewards Points: 2,864
Joed has a very good point. Some controllers will sense the presence of a device on the bus even if it is not powered. That can result in some funky behavior.
mpoulton is offline   Reply With Quote
Old 01-06-2012, 11:58 PM   #19
Rewards Points: 6,652
That is why I suggested the SATA controller tray with the key switch, since this will eliminate that possibility. Same with the hot swap tray.
Old 01-07-2012, 01:47 AM   #20
Rewards Points: 225
It's a matter of cost. The switch costs $4. As I said, I don't plan to turn the drive off once it's on. I've never had a problem (that I know of..) with a device being sensed even though it is not receiving power. My setup is currently I leave an SATA cable connected to each device and just plug in power if I need that device. If I was turning a powered drive off I would go with a hot swap, definitely.
Thanks again
Deck is offline   Reply With Quote
Old 01-07-2012, 01:57 AM   #21
Thanks again
You will have a problem if you use the switch. Go with either type of tray that I linked, and the choice is your's.
Old 01-08-2012, 12:15 AM   #22
Canadian home owner
If you switch it on or off when the computer is off there wont be a problem.
And your switch arrangement is just fine too. Switch both ground wires, they end up in the same place.
pw5599 is offline   Reply With Quote
Old 01-14-2012, 05:21 PM   #23
Rewards Points: 225
An update: I did end up buying the switch. The device (a hard drive) received power even when the switch was off. I disconnected the ground wires from the switch to confirm. I would guess what was happening is the SATA connector that was connected to the drive has a ground in it and therefore the drive just used that ground. I tested this theory by disconnecting the SATA wire which disconnected the power.
You learn something new every day. It appears there is no way for me to get around this other than the hotswap or a DPST on the +12 and +5. At this point I'll probably go with the hotswap.
Tags
dpst , molex , power , switch
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 10:08 AM
Ground Wires Connected Outside of Switch Box Cannun Electrical 3 12-16-2011 08:32 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
