Any Electricians Out There? Panel Upgrade! - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2005, 02:46 PM   #1
Any electricians out there? Panel upgrade!
Have a question for any electricians out there! What needs to be done to upgrade from a 60 amp fuse box to a 100 amp panel? Is it a mtter of replacing the fuse box with a 100 amp panel or does the wire have to be upgraded as well as the meter box? Would anything less then 100 amp wire be ran to the house? Is the wire ran for a 60 amp fuse box able to carry 100 amps? Any help is appreciated. Thank You!
roncon is offline   Reply With Quote
Old 06-19-2005, 01:38 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Any and all wire will need to be able to handle 100 amps. Also the meter base may need to be upgraded. 100 amps is the min. required for a house. The poco wires may be able to handle the upgrade, but you will need to contact them.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
Add subpanel or upgrade main panel dcoz Electrical 1 01-12-2006 10:24 AM
