Any Code Involving Downsizing Neutral And Ground For A Subpanel? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2012, 08:28 PM   #1
Rewards Points: 502
Any code involving downsizing Neutral and Ground for a subpanel?
I am planning on a couple of subpannels that will be required to supply fairly robust 240v load, but minimal 120v loads. I was thinking of running 00/2 - 2/2 (maybe a size smaller, I haven't measured the run yet). would that pass code?
forresth is offline   Reply With Quote
Old 05-17-2012, 09:34 PM   #2
Rewards Points: 1,418
For most household applications the neutral has to be the same size as the hot conductors, but the ground wire can be somewhat smaller. The National Electric Code has a table listing the ground wire sizes.
But with a predominantly 240 volt load you might use the 240 volt calculatoin instead of the 120 volt calculation for percentage voltage drop when selecting the wire size to begin with, if the distance is considerable. Voltage drop takes into account the round trip distance. Wiith the predominantly 240 volt load the number of amperes and therefore the voltage drop in the neutral will be somewhat less than the 120 volt calculation shows, leading to an actual smaller overall percentage voltage drop fort he 120 volt loads. (The percentage voltage drop will always be greater or equal for the 120 volt loads compared with the 240 volt loads.)
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 11:58 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
