Antique Chandelier -do I Have To Rewire It? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 11:15 AM   #1
Antique Chandelier -do I have to rewire it?
Hello there,
I bought and old brass chandelier.
It has cloth wiring inside the arms.
Is it really neccessary to replace the wires?
My husband tried to pull the old wires out and they won't budge!
Thanks so much for any advice!
725peanuts is offline   Reply With Quote
Old 02-26-2012, 11:19 AM   #2
Rewards Points: 58
Depends on how good or bad the wires actually are. What is the condition of the insulation? Worn out? Broken? Evidently your husband thinks they need to be replaced. Why would he be wrong? The wires do come out and if he is pulling them and they wont budge he is not doing it right. You must remove all the sockets before anything will move. Rewiring it will be easy and a good idea depending on the condition of the wires.
There is nothing wrong with cloth insulated wires if they are in good condition.
Old 02-26-2012, 11:34 AM   #3
Thanks for your reply! My husband says the wires are cloth coated over a plastic coating. The cloth appears to be worn a little but the plastic is intact.
I hope it didn't sound like I thought he was wrong about replacing the wiring - we were both wondering what was best.
Our concern and main question was if we left the old cloth wiring in would it be a fire /electrical hazard?
We really apprieciate any advice!
Old 02-26-2012, 12:08 PM   #4
DIY staff
Rewards Points: 7,174
If the insulation is not brittle and cracking you should be fine---check near a socket---that is a 'warm' area--and the most likely to dry out and become brittle---if that's good--the rest will be fine---
two dimmers, 1 for spots 1 for chandelier help Nessa Electrical 9 02-01-2012 12:34 AM
Chandelier Wiring Questions Twister Electrical 8 06-18-2011 09:50 AM
Replacing Chandelier Green Grounding Wire? wyjadka Electrical 4 03-24-2011 07:22 PM
chandelier Connection clampion Electrical 3 03-20-2011 10:48 AM
heavier chandelier??? frgwtchr Electrical 13 07-25-2009 12:08 PM
