Antique Ceiling Fan - Starting Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2012, 05:37 PM   #1
I have an antique Emerson Electric 48641 ceiling fan made around 1920. It has been running well but now it won't start without hand spinning the blades. Does this thing have a start capacitor? Is there something else that might need to be checked?
Thanks,
Harry
plano_harry is offline   Reply With Quote
Old 09-08-2012, 06:21 PM   #2
Insatiable Learner
Rewards Points: 166
Smile
Made in 1920? Could be due for some lubrication
AngelArs is offline   Reply With Quote
The Following User Says Thank You to AngelArs For This Useful Post:
jrclen (09-09-2012)
Old 09-09-2012, 01:24 AM   #3
dmxtothemax's Avatar
Rewards Points: 5,098
I would be looking for a start capacitor !
dmxtothemax is offline   Reply With Quote
Old 09-09-2012, 01:27 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Not for old style Hunter / Emerson fans they will have either run capaitor or PSC windings that about it.
Due the age of the fan motour that is pretty old one and I just took one down not too long ago and it did have a run capaitor in there no start capaitors at all.
Merci,
Marc
Old 09-09-2012, 09:15 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 824
How hard is it to turn by hand? You should be able to give it a spin and it will coast down slowly.
A fan like that is worth taking care of....if you don't want it.....I'll be glad to take it off your hands....
Ceiling Fan Wiring Problem drew15a Electrical 19 02-20-2012 09:19 PM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 01:15 PM
Finishing Basement..ceiling problem cornick Remodeling 12 12-08-2009 11:36 AM
Ceiling Fan Installation Problem ejbende Electrical 6 09-01-2009 10:35 AM
Ceiling fan with two pull chains (lamps and fan) , a wiring problem chats72 Electrical 3 12-30-2008 06:41 PM
