Old 09-11-2012, 10:49 PM   #1
anti short bushings for MC cable
someone told me awhile ago that using anti short bushings for MC cable is only optional but someone else more recently told me that it is actually required. it makes sense for it to be required, to be honest. just wanted to double check.
i do have some receptacles wired with MC where i did not use bushings and i also wanted to confirm that it should be possible to insert bushings from inside the receptacle after the fact (after, of course, taking the outlet or light out) and not have to pull the cable out of the receptacle.
Old 09-12-2012, 12:45 AM   #2
E2 Electrician
stickboy1375's Avatar
They are not required for MC type cable, they are required for AC type cable though... so make sure you understand the difference.
Old 09-12-2012, 01:22 AM   #3
And they are damn near impossible to install with the cable already in a connector. Of course putting them On like that sort of defeats the purpose anyway.
Evstarr is offline   Reply With Quote
Old 09-12-2012, 07:01 AM   #4
Master Electrician
Not reqyuired, easily installed, generally used. Cannot be installed throught the device box without cable removal.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
amakarevic (09-12-2012)
Cable Fastening & Cable Bundles ctlu008 Electrical 13 01-15-2012 07:43 PM
Aerial Cable to Garage & Adding Sub Panel CDW59 Electrical 5 12-09-2011 07:43 AM
Electrician best practice questions mudworm Electrical 32 11-12-2011 02:59 PM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 11:20 AM
Running Sky+ cable bookersbeauty Electrical 1 04-09-2009 08:12 PM
