Anti-oxidant And Torque On Panels For Shop. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2012, 09:23 PM   #1
Anti-oxidant and torque on panels for shop.
I just pulled 150' of 4/0 aluminum triplex, and hooked it up to my panel. I followed all directions on the panel, using anti-oxidant.
Few questions:
1. Will I ever need to re-apply anti-oxidant? I scrubbed it in with a wire brush, and then added another thin layer. After that, I torqued the allen bolts to 23 ft-lbs (275 in-lbs). There is no disconnect, so I won't be able to get near it after the PUD is done.
2. I torqued the ground to 9 ft-lbs (110 in-lbs) and the screw stripped before my torque wrench stopped? I have to get another ground connector now. Not sure why that happened... Anyone had that happen before?
3. How much insulation should be stripped off the 4/0 and 2/0 (neutral) below the connector? I left about 1/4".
Panel is a Siemens g2040b1200cu. Pic attached.
Thanks,
Todd
Newbomb is offline   Reply With Quote
Old 05-20-2012, 10:31 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Are you sure the panel can be mounted with the MB on the bottom?
Old 05-20-2012, 10:37 PM   #3
I don't believe there is such a thing as an upside down panel anymore. Yes, this one has a horizontal MB.
Todd
Old 05-20-2012, 10:56 PM   #4
k_buz's Avatar
Yes, there are restrictions on whether you can mount a panel with the MB on the bottom, but I think this one is OK.
Next question, where does the other end of the triplex terminate? Is the triplex sleeved in PVC?
Old 05-20-2012, 10:59 PM   #5
It will be connected to a CT meter provided by the PUD (Clark PUD in Vancouver, WA). It goes straight to the pedestal behind my transformer, according to PUD instructions.
I have a small amount of 2" sched 80, and 130' of 3" sched 40. The sched 40 goes up to the pedestal. The trench/conduit has already passed inspection.
Todd
Old 05-20-2012, 11:05 PM   #6
k_buz's Avatar
And you were specifically told to run triplex from the meter to the panel?
I'm asking because we would need a separate GEC from the meter to the panel.
Old 05-20-2012, 11:15 PM   #7
I asked about five times. Both to the PUD and the inspectors (L&I). They said b/c it was a secondary, and it was using a CT meter that no ground was needed. Still could not convince the guy at the electrical store. He was confused.
This is not a normal installation, apparently. They are removing the meter at the house, and metering both the shop and house at the transformer. The shop/house branch in a 'Y" from the xformer. House is 400 A, and shop is 200 A.
Cost me $500 to meter them together (PUD charge) but it is $12/month for another meter. There is no meter behind this panel.
Todd
Old 05-21-2012, 09:45 AM   #8
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Few questions:
Thanks,
Todd
1. No
2. Torque to manufatcures specs. It happens.
3. Sounds fine.
4. Identify the grounded conductor.
What type of insulation does the triplex have?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
