-   -   Anti-corrosion? (http://www.diychatroom.com/f18/anti-corrosion-103105/)
WillK 04-29-2011 10:53 AM
Anti-corrosion?
In some of my searching I've read references to using anti-corrosion spray on aluminum wire. So I wanted to ask if this is necessary, if I did this is there any harm, and is this product appropriate for this purpose:
CRC 2-26 multi-purpose lubricant
http://www.crcind.com/wwwcrc/tds/TCI3%202-26.PDF
a7ecorsair 04-29-2011 11:11 AM
Go to the electrical section and get the correct stuff. It has to be L&L for the purpose.
WillK 04-29-2011 11:22 AM
Well, I guess that's the problem, not sure what the right stuff is and this is the stuff I found in the electrical section. At Home Depot. I'm not expecting to get a correct answer if I ask about this while I'm there either.
NJMarine 04-29-2011 05:04 PM
Anti-corrosion
Big box stores carry noalox, which is what you need
a7ecorsair 04-29-2011 07:28 PM
1 Attachment(s)
Like this:
junkcollector 04-29-2011 07:55 PM
A little tip: When you terminate aluminum after you coat the ends of the wires with the stuff listed above, put some on the threads of the lug screws before you tighten them. This lubricates the threads and keeps from galling them up and stripping out.:thumbsup:
