Antenna Grounding - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2010, 01:04 PM   #1
Rewards Points: 150
antenna grounding
As I live in a very low lightning part of the country I've never thought much about grounding my 1950's era tv antenna.
Now, I've spent some real money on a big old flat screen tv and I think I ought to get on it. So, can I clamp onto the ground wire that runs from my service panel to the two ground rods? What type of wire should I use?
Also, can anyone fill me in on a decent surge protector that won't break the bank? Thanks
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 07-24-2010, 07:26 AM   #2
Rewards Points: 1,500
It is common to ground a TV antenna using a ground rod. Size 6 copper wire is recommended.
I don't see why existing ground rods could not be used considering that when additional ground rods are driven, they are usually all bonded to one another although this last step is often omitted if there is a distance between them.
It is also suggested from time to time to bond all the components of an audio or home theater system by daisy chaining the items to one another using a #12 or even #14 copper wire and grounding it all with the far end of the wire connected to a known ground. Either the outer shell of an input jack or a screw that reaches through to the metal chassis can be used as an attachment point for the bonding wire.
Old 07-24-2010, 03:42 PM   #3
Electrician
Proby's Avatar
Run a #10 down from the mast to the GEC like you talked about, use a split bolt connector. If you were to drive another ground rod and not bond it to your electrical system, you can introduce ground loop problems.
Proby is offline   Reply With Quote
Old 07-24-2010, 03:53 PM   #4
I'd put the flatscreen on a UPS too
Had an antenna at the parents house as a kid
He never had me ground it...I was responsible for installation
And he knew about electrical etc
My current antenna is in the attic -I use it for radio reception
Old 07-25-2010, 02:29 AM   #5
Rewards Points: 150
Ups ???
Warren Zevon
Old 07-25-2010, 04:24 AM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by handifoot View Post
Ups ???
as in UPS
Disclaimer
& Stay Safe
.....Bob Lavery
What about lightening rod when they do my roof? Leah Frances Electrical 7 06-04-2009 04:34 PM
OTA antenna ground DIYGST Electrical 8 03-09-2009 01:39 PM
Grounding my new over-the-air HDTV antenna pcampbell Electrical 2 01-15-2009 11:42 AM
Grounding Antenna Piedmont Electrical 12 11-29-2007 03:34 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
