Another Sub Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2012, 08:15 AM   #1
Another Sub panel question
So I've read enough forum topics to make my brain melt but still I'm a little unsure as to what wire I need so here's what I have:
200A main panel will be feeding my barn that is 175ft away, in the barn I plan on installing lights and 2 outlets. So I planned on installing a sub panel with 2 20A breakers one for the lights and one for the 2 outlets. Will #8 THWN work? Thanks in advance
combs&co is offline   Reply With Quote
Old 08-29-2012, 10:28 AM   #2
Rewards Points: 160
Use this calculator to determine the size wire you need for your run. You must pick your current requirement (panel). http://www.southwire.com/support/vol...calculator.htm
Old 08-29-2012, 10:48 AM   #3
yeap
Thanks J. V. I was looking for a calculator that made it easy for the DIY'er
Old 08-29-2012, 01:02 PM   #4
kevinp22's Avatar
Rewards Points: 252
Combs,
It cant be made simpler because you have to make the following decisions:
1. Do you actually need a sub-panel or would a single 20A circuit or a 20A MWBC do the job
2. If you do a subpanel, what size. If in doubt, upsize to allow for future growth. Remember a sub-panel has to have its own grounding system in addition to the ground provided from the line to the main panel.
3. Voltage drop. at 175 feet voltage drop enters into play. Probably upsize at least 2. So for example, for the 20 amp MWBC, you would use at least 10 AWG, not 12.
kevinp22 is offline   Reply With Quote
Sub panel question Dogger Electrical 1 09-28-2011 04:48 PM
Question about sub panel lilryry Electrical 12 07-29-2011 11:32 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 03:27 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
