Another (slightly Different) Ceiling Fan Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2008, 09:30 AM   #1
Another (slightly different) ceiling fan question
Hi all,
My situation is thus.... Our bedroom has a tray ceiling with four dimming spot lights near each corner. We are going to install a fan (prossibly with no light) in the middle of the ceiling and want to keep the lights on a seperate switch. I can get above the ceiling to add a support box and run a wire for the fan down to the current light switch in the wall.
My questions are thus: Do I need to add a seperate box to house the switch in the wall or can a 'dual' control switch like the Hunter 27183 work with two wires in the one box? http://www.homedepot.com/webapp/wcs/...10000003+90010
I imagine that I need to add a second box if the fan will also have a light too? If so, what's the best way to get power to it assuming it would be next to the existing switch?
Thanks in advance!!!!
risherry is offline   Reply With Quote
Old 10-11-2008, 02:12 PM   #2
Rewards Points: 506
Send a message via AIM to theatretch85
By "tray ceiling" I assume you mean a dropped ceiling with ceiling tiles?
That switch will work, except instead of both wires coming off the switch and going to the fan box, the light dimmer would go to your existing lights, and the fan control would go to the fan. You could put a light on the ceiling fan and control it from the same light dimmer (provided you don't exceed the rating of the dimmer). Usually the dimmers are only rated for about 300 watts, so you will have to check; also will depend on the wattage of the bulbs you are using.
To make that box accept 2 switches down the road, you could simply cut the drywall big enough for a 2 gang box, rip out the old single gang box and put in an "old work" 2 gang box feeding the existing wires into it.
theatretch85 is offline   Reply With Quote
Old 10-12-2008, 08:23 AM   #3
Thanks for the input!!!!
As and FYI, As a 'tray' ceiling, I mean't that the middle portion (from about 2' from each wall) is raised about 2+' feet, making most of the ceiling ~11'. It's all drywall, not tiles.
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
ceiling white - crown molding color question remodelingagain Interior Decorating 3 06-06-2008 01:16 PM
Question regarding removing ceiling joists... tonfan Building & Construction 9 11-18-2007 11:56 PM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
Question about ceiling joists... StlJoe Building & Construction 5 12-06-2005 11:52 AM
