Another Pool Bonding Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2009, 07:27 PM   #1
RustyRealtor's Avatar
Rewards Points: 283
Hello,
I was reading the thread started by "shaggysteele" and it relates to my question. I bought a pool home which used to be under an aluminum screened enclosure. The enclosure was removed by a hurricane. Just outside the concrete pool deck, protruding about a foot from the grass is a #8 copper ground wire which is attached to nothing. I dug down with my hand and the wire is coming from under the concrete pool deck. The wire is not long enough to reach the pool pump, so I assumed it must've been attached to the pool enclosure. Tomorrow I am going to post some photos of the situation. Does it seem as though this could be the bonding wire? If so, would it have been attached the the screen enclosure?
Many Thanks,
Russell
RustyRealtor is offline   Reply With Quote
Old 08-04-2009, 07:32 PM   #2
Is there also a wire attached to the pump?
If not look around the pump area
Yes - the metal screen house would have been attached
Old 08-04-2009, 07:36 PM   #3
Rewards Points: 283
Thanks for the reply. I am not sure about the pump. I will look tomorrow. If I have to attach this wire to the pump, I will need to extend the wire. It is dark now and I am not at the house.
I love this forum!
Thanks,
Russell
Old 08-05-2009, 01:02 PM   #4
Rewards Points: 283
Hello Again,
I've attached some photos (I think). There is a bonding wire to the pump. One of the photos shows another bonding wire coming out of the ground. Can I add mount this wire on top of the other wire on the pump? If so, is there a special connector to lengthen the wire so it will reach the pump?
Also, as seen by one of the photos, the junction box is not supported by metal raceways. Is this cause for concern?
Another Pool Bonding Question-pump.jpg   Another Pool Bonding Question-8-copper-wire.jpg   Another Pool Bonding Question-junction-box-opened.jpg
Thanks,
Russell
Old 08-05-2009, 01:15 PM   #5
Is the junction box mounted to a wall?
I mounted mine on a PT 2x4 in the ground
As long as there is a bonding wire to the pump that is all that is needed
If it's close you could run the other wire over to the pump too
But both wires are probably connected under the slab
I'd fix that flex line connection
Bonding for Pool Equipment Elecman Electrical 9 03-23-2010 03:09 AM
pool bonding question.? pjwinstalls Electrical 5 06-28-2009 01:32 AM
Pool Motor Question...Please Help! gmcf2004 Electrical 13 06-01-2009 07:34 PM
Inground Vinyl Pool Question intofire Landscaping & Lawn Care 0 09-11-2008 10:34 AM
