Another Neutral Bonding Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 12:19 AM   #1
Rewards Points: 506
Saturday I helped father-in-law pull a little portable generator out of the barn and prep it for the upcoming weather...just in case. I measured for voltage in a normal fashion. Meter realized 110v between the 2 CCCs, but realized 0v between hot & ground. I subsequently tested for continuity between 'neutral' & ground and found none.
Is this generator in disrepair or was it manufactured in this fashion? I've read some threads about floating neutrals(?). This is a portable gen. with only one 120v recept, so I can't imagine it being used with a transfer switch. Why would the neutral and ground not be bonded?
jlmran is offline   Reply With Quote
Old 02-01-2011, 07:08 AM   #2
Rewards Points: 1,418
Portable generators normally have an optional neutral to ground (generator frame) bonding.
In the field (not powering a home electrical system) the neutral and ground should be bonded.
FOr a home main panel connection, the generator's frame should not be bonded to neutral. When connected via a standard 4 wire (hot, hot, neutral, ground) (3 wire hot, neutral, ground for 120 volt generators) cable the frame and neutral will become bonded via the main panel neutral/ground bonding.
When you have a subpanel that is wholly transferred to the generator (only the subpanel circuits get generator power) then the generator neutral and ground should be bonded.
Old 02-01-2011, 07:21 AM   #3
Portable
Old 02-01-2011, 07:43 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
It's not optional. Most have the neutral bonded from the factory.
Not true for a portable unit that is connected to the house by a cord and plug.
If a genset is permanently wired to the home's system then the neutral must be isolated.
Old 02-01-2011, 08:48 AM   #5
Rewards Points: 506
So, evidently father-in-law doesn't have one of the most?
It seems that a portable generator without a N-G bond could be quite hazardous. I still don't understand why it is permitted to be manufactured in this manner?
Old 02-01-2011, 08:54 AM   #6
Rewards Points: 506
Why? I'm not understanding the logic.
Old 02-01-2011, 09:25 AM   #7
In a home system, including the generator when switched to generator power, there may be only one locations where neutral and ground are bonded, and normally that location is the main panel.
(When a subpanel is transferred exclusively to a generator, we now have two systems, (1) the generator and that subpanel and associated branch circuits, and (2) everything else, probably dead at that moment.)
I suppose there is an exception for a cord and plug connected generator so it is not necessary to dissect a generator without a visible removable neutral/ground bond.
Old 02-01-2011, 10:10 AM   #8
Rewards Points: 506
Seems to me that having a generator attached to a home system with two (2) separate N-G bonds is way less hazardous than having a portable generator without a N-G bond.
If this statement is true then I'm suprised that all generators simply don't all have a factory-installed N-G bond.
Again, the original post was about a small, portable generator which does not appear to have a field-serviceable N-G bonding option.
Old 02-01-2011, 10:42 AM   #9
If your unbonded generator does not have a neutral ground bond option, you can create one almost as a no-brainer. Example: make an adapter with a cord and plug coming out of a small junction box with receptacles and the bond inside the latter. Plug this into your generator and plug the extension cords for your tools into this.
Some experts say that an unbonded generator is better for double insulated and two prong tools. This way a fault to the body of the tool can't let current use your body as an alternate route to get to the ground and up into the generator sitting on the ground.
FAQ Draft Gigs Electrical 36 03-26-2009 11:54 AM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 04:15 PM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 11:18 PM
Bonding & Ground Rod Question bradsguns Electrical 3 06-13-2008 01:55 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
