Old 09-16-2012, 12:05 PM   #1
Another GFCI Question
I have run two circuits for my counters, ]
A. The fist wall has a fridge outlet below counter and then 1 GFCI downstream (single protection, so its not protecting the fridge). I'm just not sure why my electrician felt it necessary to pigtail the fridge outlet.
I thought as long as the GFCI was downstream you would not have to do that?? Any thoughts???
B. The other circuit is on anther wall with two counter GFCI and one outlet below gas oven for the ovens igniter, clock/panel.
The order of the receptacles (wires not fully run yet) is:
Counter outlet---> oven outlet (below counter)---> last counter outlet.
I figured to not protect the oven on the GFCI, so will the setup i'll describe below make sense?
Line (Hot)--->1st outlet (GFCI) on its "line studs" pig tailed
to----> load (run) that goes to the oven outlet.
Simultaneously, the "load studs" on that 1st outlet GFCI will then run to the second counter outlet (non GFCI) to make it GFCI protected?
My goal is to run the cable in physical order of the pass and make the two counter GFCI protected and the oven not.
Will this cause faulty tripping, is it to code, and safe, and practical?
I could run pass the first counter, hit the oven first, then go to the first outlet (GFCI), and then the last?
Jzone99 is offline   Reply With Quote
Old 09-16-2012, 12:54 PM   #2
A) It's personal preference on pig-tailing the conductors, some do, some don't.
B) As long as the receptacle for the gas range is more than 6ft away from the sink it does not need GFCI protection
Would be better to run to oven first, as long as (B) does not apply.
Gac66610 is offline   Reply With Quote
Old 09-16-2012, 01:02 PM   #3
E2 Electrician
stickboy1375's Avatar
Originally Posted by Gac66610 View Post
A)
If that receptacle is not serving the counter top, then GFCI protection is not required.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
brric (09-16-2012), Gac66610 (09-16-2012)
Old 09-16-2012, 01:15 PM   #4
Yes, I'm sure the oven does not have to be GFCI protected, I was not questioning the logistics of the arrangement (B). I just wanted confirmation B will be correct based on my proposed setup since it has one Line in and two loads out, one hot load going to the oven not GFCI protect by pig tailing and the other load going to the other counter GFCI protected since it will be coming off the studs.
Old 09-16-2012, 01:20 PM   #5
E2 Electrician
You can wire it anyway you want, but the receptacles serving the counter top must be GFCI protected. And you need two circuits serving the counter top.
Old 09-16-2012, 02:56 PM   #6
Average Joe/ex-Navy IC3
gregzoll's Avatar
To make things simple, have one 20amp circuit serving the outlets for the fridge, stove, and a couple of baseboards, make the counters exclusively GFCI. Remember the KISS principle. If you wanted to, you could make all outlets regardless of their location on either the upper part at the counters, lower along the baseboards served by a gfci protection as the NEC states.
It states "min." 2 20 amp small appliance branch circuits in the Kitchen, but the kicker is, they are not exclusive to just serving counters only.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
GFCI question regarding hardwired vs plug-in disposal mystic_cobra Electrical 24 04-13-2012 07:26 PM
GFCI outlet and breaker question danette32 Electrical 5 02-11-2012 06:25 PM
GFCI Conduit question llenod Electrical 3 04-06-2011 01:09 PM
GFCI question. Please Help. the banana k1ng Electrical 4 10-09-2009 08:35 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
