Another Electrical Rough In Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 08:08 AM   #1
Rewards Points: 81
Sorry for all the newbie questions lately:
I am building a sound proof room and trying to limit any penetrations through lights and outlets.
My outlets will be covered with fire putty pads to help but my concerns are with my lights. I am building my soffits AFTER my room is soundproofed with layers of sheetrock and I plan to put my lights in my soffits.
Obviously for the outlets I need to have my rough in inspection prior to sheetrock but what do I do with the wall lights? Can I run my wire and just have the junction box hanging from the ceiling to where the soffit will be?
There will be no load since they'll be on their own circuit.
LarryM is offline   Reply With Quote
Old 06-08-2012, 08:12 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You should be fine, but for final inspection you will need to have the boxes up and fixtures up.
Old 06-08-2012, 09:14 AM   #3
Rewards Points: 81
Thanks!
Old 06-08-2012, 09:20 AM   #4
Licensed electrician
Rewards Points: 1,238
I had a thought that might work. Just install a part of a sheet of drywall where the soffit will go and build the framework for the soffit. This way the inspector can see the boxes where the fixtures will be and that the cables are secured.
There would be no additional drywall work as there is already an inside corner that would need to be finished where the soffit meets the wall and ceiling.
Old 06-08-2012, 11:03 AM   #5
Rewards Points: 81
I thought of that but then I would be blocking the fireblocking that I am doing and the construction official won't be pleased with that.
Tough pickle I am in but I am going to go with K Buz's recommendation.
bathtub rough in question: slip joint or glue pttcc Plumbing 2 09-16-2010 08:12 AM
Old Electrical Box Insurance Question bailey35 Electrical 4 06-29-2010 02:58 PM
well pump electrical multimeter question tpolk Electrical 21 04-28-2010 11:37 PM
Important Wire Nut and Electrical Tape Question Wolfies167 Electrical 22 01-06-2010 01:59 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 07:07 PM
