Old 10-24-2007, 05:16 PM   #1
Another Dumb question - Self grounding outlets
This old home stuff is getting to me. I'm used to plastic box installs and a ground pigtail to the outlet. The current old home we bought has a combination of plastic and metal boxes. I've found an online source for ordering self-grounding outlets ($3.97 for box of 10). My question is do all self grounding outlets also include a ground terminal for plastic box applications? The lady on the phone said it did but I'm not certain she understood my question, so I'm checking with the experts. Me, I'd rather ground both box and outlet and not rely on the spring clip, but the price seems hard to beat, otherwise I'd go with Levitons or similar. As an alternative, is their a good online source to purchase boxes of outlets?
robertmee is offline   Reply With Quote
Old 10-24-2007, 06:15 PM   #2
Licensed electrician
Before you think about installing the self grounding devices you need to verify whether your wiring method can be used to provide the ground.
How old is the house wiring and what type of cables or conduit was used?
Old 10-24-2007, 06:19 PM   #3
No conduit, each 12/2 has a green ground wire. Appears to be standard white jacketed romex.
Old 10-24-2007, 11:53 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Yes all receptacle types have a green screw for grounding. $3.97 for ten outlets give me concern though. That is slightly above the price of one good quality self grounding outlet yet alone 10 of them. Also if you have a green ground wire in romex your house is haunted.....
Stubbie
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 10-25-2007, 08:23 AM   #5
Stubbie
Why is it haunted? I'm used to bare, but this Romex has an insulated green, although it's a weird insulation. It's rectangular instead of round. And very stiff, almost like paper based instead of polymer. But it is definitely formed insulation (not a paper wrap) and requires strippers to remove.
BTW, here's the link to the outlets, if anyone has any experience ordering from them: http://www.kk-lite.com/p/wiring-devi...klid=30-R15-SW
Old 10-25-2007, 09:21 AM   #6
Licensed Pro
And I'll bet the ground wire is a smaller gauge than the other (#16). Early NM cable with ground was made like this. Probably from the early '60s.
Old 10-25-2007, 09:35 AM   #7
Yep, exactly. It is smaller.
Old 10-25-2007, 01:02 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Sorry.... just a figure of speech about the ground wire. It is sort of an inside joke around my area as we have a lot of older homes (1960 or so) with romex made by essex wire that has this green ground. A few strange occurrences have been noted in some of these homes....
Anyway the receptacles are most likely going to be the very low end of quality and I would suggest a better quality receptacle that has the metal yoke wrapped around the back of the receptacle instead of the glued together type on that web site.
Stubbie
Stubbie
Old 10-25-2007, 01:34 PM   #9
Stubbie
Any online sources for purchasing good, but economical receptacles? I'm going to have to replace them all in this home as the previous owners painted them brown. I know paint on an outlet is an NEC no-no.
Old 10-25-2007, 02:49 PM   #10
I have never had a problem with the Pass and Seymour 3232 type receptacles
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 10:49 AM
Question on Grounding ayudi General Discussion 2 12-11-2006 05:14 AM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 06:44 AM
