Another Ceiling Fan Hook-up Question(with Remote) - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2009, 05:23 PM   #1
Another ceiling fan hook-up question(with remote)
My old fan has the basic white to white-black to black-red to black(for light)
the wall switch operates the ceiling fan motor and light. to sep. wall switches.
my new fan has a remote with white and black and blue
then just white and black to supply circuit.
(also grounds)
my questions.
what to do to the red?
when i hook up everything whites to whites, black to black even black to red and black turn on power and nothing happens when the remote is pressed.
iv'e tried with switches off and on.(light kit on fan is not hooked up yet)
any thoughts???
tommy281 is offline   Reply With Quote
Old 11-04-2009, 06:10 PM   #2
In the manual under troubleshooting it states.
do not connect fan with wall mounted speed controls.
maybe a re-wire in there is in order although with both switches on full id think it should work?
Old 11-04-2009, 07:22 PM   #3
Ok iv'e got it working
now another question.
I also hooked the fan up with-out the remote
power supply- -------------fan
white----------------- white
black-------------------- black
red--------------------- blue
all grounds
everything seemed to work fine. so my question is. do i have to use the remote?? any danger to the fan by not using the remote??
thanks-
Old 11-04-2009, 07:25 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
Take the speed control out and install a on/off toggle switch. Cap the red wires on both ends and you will be good to go.
Does the remote wire up in the canopy?
You do not have to use the remote if it is a stand alone unit.
Old 11-04-2009, 08:03 PM   #5
No. You have separate switch legs for the fan and light so they can be controlled via the existing switch(es).
220/221 is offline   Reply With Quote
Old 11-04-2009, 08:17 PM   #6
Child Alert! Pull Up!
fltdek's Avatar
I second JBFAN, get rid of your old switch, replace it with a light switch, you will NOT be using the red wire, so cap it off, tape it up, push it in the back of the box on both ends.
The remote control is not necessary, but...do you have pull strings with the fan to control the speed or light (other than cutting it off by the wall switch) - if no pull string, then you maybe stuck with using the remote.
fltdek is offline   Reply With Quote
Old 11-04-2009, 08:20 PM   #7
Thanks no strings. I do have two seperate wires for the light and fan speed.
why replace the switch??
after hooking everything up(no remote)the light dim switch will not dim the lights (candelabra bulbs)only high setting.
the fan speed seems to be working ok.
Old 11-04-2009, 09:38 PM   #8
Ok iv'e hooked up the remote as the fan operation is more smooth.
Old 11-04-2009, 09:59 PM   #9
I can tell im going to hate the remote
maybe a slider switch would work??
Old 11-04-2009, 10:06 PM   #10
fltdek's Avatar
I had to take a second look at the switch, realizing its a dimmer switch, so I guess if you wanted to control the fan that way you could, but seeing that you have the remote hooked up, probably not worth removing the remote at this point, just leave the switches at full setting for using the remote and or use the switches.
Old 11-04-2009, 10:09 PM   #11
fltdek's Avatar
Something else to consider, remotes dont last forever, the receivers go bad, hang on to your owners manual and receipt for warranty purposes, in the event you need a replacement.
Old 11-04-2009, 11:12 PM   #12
Thanks-
The remote goes up in the base of the fan. right where the wires get stuffed in the ceiling box. ya, its in the way.....
just dont like the remote.
Im going to pick up something like this-
hopfully it will work
3-way wiring- ceiling fan with remote for two-wire hookup mr_snuffle Electrical 24 08-16-2009 12:01 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
ceiling fan remote craines Electrical 6 01-26-2009 09:02 PM
Converting ceiling fan wall controls to remote crappyhandyman Electrical 5 08-02-2008 10:58 AM
Hampton Bay Remote Ceiling Fan esqjd Electrical 16 01-14-2008 06:32 AM
