Old 10-26-2010, 12:35 AM   #1
Another cabinet lighting question
I will be putting some LEDS under cabinet lighting. The walls will be open. I will most likely mount a switched plug above the cabinets (will be hidden from view). I plan on running 3 wiring whips to the 3 sections of cabinets where the lights will be. Above the cabinet i will splice the whips to the transformer and then plug it into the receptacle. Couple of questions:
For puck lights that are pressed into holes cut in the cabinet bases, what is done to hide the wiring in the cabinet?
If i put in strip lights, how do you hide the wiring?
Pics of installs would be great! Thanks
bcbud3 is offline   Reply With Quote
cabinet screw question HELP ckr31 General Discussion 3 10-05-2010 06:26 PM
under cabinet lighting jim1464 General Discussion 6 09-24-2010 10:07 AM
LED Under Cabinet Lighting Kstrats Electrical 2 07-28-2009 01:49 PM
Another question about landscape lighting kimberland30 Landscaping & Lawn Care 4 05-01-2009 08:44 AM
