#16 | ||
Analog multimeter shows voltage even with 3-way switch offQuote:
The panel is fed from a single conduit from a metered box. The feed is on 3 high gauge lines. I'm not sure exactly what but it looked like standard, heavy duty, outdoor, cabling, approx a half inch in diameter, "USE Type" I think its called? Two of the lines come into the panel and go to the top of the main breaker for the house. The 3rd high gauge line connects to a large ground terminal strip. Off this strip there are many bare ground and neutral(white) wires screwed into the terminals. A few are shared, yes I am aware this is not to code? and this was per-existing, I have done no work inside the panel, but some minor work was done by licensed electricians. This was fixing the wiring to the Air conditioning to be to code (higher gauge wire and to solid copper with a properly mounted box), and replacing an old 20A breaker that fed some bedrooms. Looking around inside the basement ceiling I don't see any place that a ground line is necessarily attached to a cold water pipe but there is a thicker braided ground that goes into the house conduit so its possible that is there somewhere and I haven't found it just yet. However, there are no ground stakes at all and no visible ground connection outside of the panel. I do see a ground connection for cable TV that has a single wire going to a junction box for that ground. I haven't seen a gas ground but I was not looking for one at the time so I would have to examine further. Would this be a ground from the outside line or is this an internal connection? |
#17 |
Master Electrician
Your earth ground would connect to either a water pipe or a ground rod from the same bar in the panel that has all the neutrals and grounds. It should be 6awg or so. If its missing its a big deal. What your reading around the internet is that in older homes many times there's no grounds run in the branch circuits supplying the various devices in your home. The main panel ground has always been a requirement. It is something that you can likely do yourself with little problem. My familiarity with the nec is limited but the above poster is usually pretty accurate with his code so I would take that as to the requirements you need to do this ground.
To put it in perspective no main ground is like jumping out of a plane with no parachute. A lightning strike will wreck havoc on your appliances and your breakers have no reference point with which to work from. Also you now have no low impedance path for the current to travel on a short circuit and your body(high impedance path) can easily become that path.
Sarcasm is my friend I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own. Last edited by andrew79; 09-22-2012 at 05:27 PM. |
| The Following User Says Thank You to andrew79 For This Useful Post: | OCPik4chu (10-02-2012) |
#18 | |
Yes I do intend to get the earth ground issue corrected, I am certainly aware that its a major problem. It just boggles my mind how builders can get away with crap like this though. |
| Tags |
3-way, aluminum wire, diy, multimeter ![]() |
| Display Modes | |
| Help! Door jamb switch saga continues!!! | dhartlein | Electrical | 3 | 08-29-2012 06:24 PM |
| Can someone tell me why my low voltage lights are reading high current at the switch? | kmc | Electrical | 5 | 06-04-2012 10:38 PM |
| B&S Generator with Connecticut Electric Xfer Switch | Rick5150 | Electrical | 19 | 01-20-2011 11:14 PM |
| Carrier Infinity 69 Trouble Code 42 | bodya1 | HVAC | 4 | 12-05-2010 07:43 PM |
| Modification to an existing pump switch | DRBLKJK | Electrical | 10 | 08-23-2009 04:06 PM |
