Amped Up - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 01:14 PM   #1
amped up
Can 14 guage wire be protected by 30 amp fuses?
aahi is offline   Reply With Quote
Old 09-19-2012, 01:36 PM   #2
DIY Enthusiast
sublime2's Avatar
No. 15 amp.
sublime2 is offline   Reply With Quote
Old 09-19-2012, 01:39 PM   #3
Code05's Avatar
Rewards Points: 1,104
In general, no, #14 is limited to 15 amps for general branch circuits.
Can you be more specific, ie; Is this a motor or HVAC load?
Code05 is offline   Reply With Quote
The Following 2 Users Say Thank You to Code05 For This Useful Post:
electures (09-19-2012), stickboy1375 (09-19-2012)
Old 09-19-2012, 05:57 PM   #4
Julius793's Avatar
Last time I saw that the insulation had burnt off the wires and where shorting out.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-19-2012, 06:08 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Totally depends on the installation type. Hmm, didnt mean to quote you.
Old 09-19-2012, 10:57 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 830
Correct......
Most of us are used to using NEC rules for wire size.
Technically, a 14AWG wire can handle 32A if used for chassis wiring.....in other words...for short distances, yea, it would work.....but.....not a good idea....I would never do that.....
I design control panels....the smallest wire I spec is 14AWG....if the current is going to be over 15A....I bump it up to 12AWG....and that is inside the panel...
When you start putting a lot of wires into a Panduit gutter....temp rise is a factor....
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
gregzoll (09-20-2012)
Old 09-19-2012, 11:18 PM   #7
Master Electrician
we just had a new provision put in that states that if there's no other option in the panel for overcurrent then 14 can go under a 20a breaker, but it's a last resort.
Basically this will create a giant sh!tstorm as it's totally up to the individual inspector as to the "no other option, last resort" part.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 09-20-2012, 12:15 PM   #8
Rewards Points: 58
Depends on the application.
Originally Posted by ddawg16 View Post
Correct......
Where do you get that #14 is good for 32 amp? I mean I am certain it would carry 100 amps for a very short period of time. Unless you work for UL I doubt your statement is verifiable.
Control panels. What size KVA control xfmr would dictate number 14 wire? How many control panels actually require a 15 amp rated control circuit?
And what load (coil, relay, timer, PLC) in the control panel would require number 12 wire.
What I am saying is you don't spec wire size to what you think, you size it to the current. This will lead to most all relay and PLC logic control panels to wire sizes well below #14.
Larger loads originating and leaving the control panel do require larger conductors. This is calculated in article Table 430.52, for motor OL protection and 310.15B for conductor size.
Saying you use 14 and 12 exclusively would not be an NEC compliant approach. Control panels are included and covered in the NEC.
Just a note. I prefer the smallest conductors possible for control panel interior wiring for elements like coils and relays.
I have found that #14 is rarely needed and takes up to much room in wire channel. Especially if you use MTW wire.
Where is this provision? If you have number 14 wire you need a 15 amp breaker, unless it is an exception like a motor circuit.
The NEC is very clear on this.
Old 09-20-2012, 12:32 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 830
Here is one of many available links to the charts...
http://www.powerstream.com/Wire_Size.htm
I've been designing control systems for 'many' years.
The 14AWG is a UL spec for control panels under UL508A.
It's important to understand that I segregate my power. 480 stuff will either be in an MCC or seperate panel. My typical control panel will usually use less than 20A total...system with more power requirements will have an external load center fed from my control transformer....(typically 10Kw and located in the MCC)
And...yes...I use lots of PLC's....real expensive PLC's....
Old 09-20-2012, 03:21 PM   #10
Master Electrician
That's because I'm not under the nec. Take a look at my location before you rip on me next time.
Swamp cooler keeps blowing buss fuse on low speed GRed Electrical 14 07-08-2012 07:43 PM
