Amp Trap - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 08:10 AM   #1
Amp Trap
I have a Amp Trap A30QS800-4 I'm working with 265-volts & 2000 amps. Will this fuse work for me with out restricting any volts or amps. Thanks in advance. R Dove.
R Dove is offline   Reply With Quote
Old 11-20-2011, 08:13 AM   #2
Electrician
Rewards Points: 802
So far from the realm of DIY, you need to hire an electrician for this.
darren is offline   Reply With Quote
Old 11-20-2011, 08:33 AM   #3
Sparky
Rewards Points: 510
800A fuse, if you're using 2000a you wont even be close to being able to use it all without blowing that
Techy is offline   Reply With Quote
Old 11-20-2011, 08:40 AM   #4
Licensed electrician
Rewards Points: 1,892
The purpose of a fuse or breaker is to limit amps to a safe load on the conductors.
Old 11-20-2011, 09:18 AM   #5
OK Sorry Guys. I was sent here by another forum. I am working with direct current & trying to figure out this fuse thing. I need a fuse. But I need one that will let me get all 260 volts & all 2000 amps... Am I asking to much from a fuse. Thanks again !
Old 11-20-2011, 09:22 AM   #6
Fuses come in different voltages and ampacity ratings.
The one you have will only let 800 amps through before blowing.
R Dove (11-20-2011)
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
Drum Trap Replacement RickyBobby Plumbing 4 02-28-2011 06:59 AM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
