Amateur Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 10:51 AM   #16
Rewards Points: 150
Originally Posted by Jackofall1
You have heard it already so I won't harp on it, but the previous posts although abrasive are correct.
The question I have is, when you shorted the line did you indeed get any sparks? You haven't said whether you did or not.
If you did then I would be looking at replacing the breaker.
If you did not get sparks then you didn't ground the circuit (a foolish thing to do intentionally)
Any time line comes in contact with neutral or ground without a load (a dead short) the breaker must trip, if it doesn't then the breaker is faulty.
Mark
Yea I did ground the circuit and yes I did get sparks
Sunny B. is offline   Reply With Quote
Old 09-14-2011, 10:54 AM   #17
Code05's Avatar
Rewards Points: 1,104
Originally Posted by Sunny B. View Post
They are both bonded to the electrode. That's why I think the equipment ground acted as the grounded conductor in that situation
A GEC and an electrode have nothing to do with a breaker tripping.
Code05 is offline   Reply With Quote
Old 09-14-2011, 11:42 AM   #18
Rewards Points: 150
I know that. I'm saying that's why it didn't trip. I was completing the circuit. Would u agree?
Old 09-14-2011, 11:54 AM   #19
Code05's Avatar
Nope.
Old 09-14-2011, 12:04 PM   #20
Rewards Points: 1,538
The significant bonding in this discussion is where the ground wire (equipment grounding conductor; EGC) from the receptacle in question connects to the fat service entrance neutral. Most likely this is through the ground bus bar of the breaker panel then through the back of the panel to the neutral bus bar.
Old 09-14-2011, 12:18 PM   #21
Rewards Points: 150
The jumper
Old 09-14-2011, 12:20 PM   #22
Rewards Points: 150
Nope.
If take a already installed receptical and swap the neutral and the ground, wouldn't that receptical still work?
Old 09-14-2011, 12:23 PM   #23
Rewards Points: 150
The more I think about it, the more I think I was completing the circuit
Old 09-14-2011, 12:36 PM   #24
Code05's Avatar
Of course it would work, electrons do not know the difference in wires.
This a theoretical answer only.
Old 09-14-2011, 12:38 PM   #25
Code05's Avatar
I think you need to go to school/classes. You lack basic training.
I sound harsh, but it is true.
The Following User Says Thank You to Code05 For This Useful Post:
Jim Port (09-14-2011)
Old 09-14-2011, 12:44 PM   #26
Rewards Points: 150
I hate it when someone insults my intelligence! I just asked if I was completing the circuit by touching the hot and GEC together and "YOU SAID NO". Then you come back with your last post. Your contradicting yourself here dude.
Old 09-14-2011, 12:46 PM   #27
fabrk8r
fabrk8r's Avatar
I'm wondering what the boss was thinking in having someone with no training, a self proclaimed "amateur", doing electrical work at a place of business.
Is this in the USA?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-14-2011, 12:49 PM   #28
Rewards Points: 150
I knew the answer to this question my friend. I was asking you to see if you knew, because your last post made me think you didn't understand
Old 09-14-2011, 12:50 PM   #29
Not a Noob or Boob
Rob1975 is offline   Reply With Quote
Old 09-14-2011, 12:53 PM   #30
Rewards Points: 150
Is this in the USA?
I never said that i was a amature, go back and read it again. And i do have training sir. I'm in my third year. And my boss likes me alot. I do great work. That's why I have gotten a raise every time I was evaluated
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Amateur Question lda130 HVAC 11 04-17-2009 07:24 AM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
