Amateur Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 08:06 AM   #1
Rewards Points: 150
Amateur question
Hey guys!! I have a question which most of you will probably feel like it's a dum question but I don't know the answer, so I'm gonna ask. I was changing a temp receptical at work and I was doing it "live". My boss was walking by and saw me so he stopped and said "I know your not working live"(that's a big no-no in my company). So being that the panel was about 50 feet from where I was, and I was feeling to lazy to walk all the way over there, i tried to trip the breaker by striking the hot across the grounding conductor but the breaker didn't trip. I was just wondering how is that possible. A coworker told me that the circuit wasn't grounded properly which I disagree with. If anyone knows, please post. Thank you!
Sunny B. is offline   Reply With Quote
Old 09-14-2011, 08:15 AM   #2
Code05's Avatar
Rewards Points: 1,104
That was a silly and dangerous thing to do.
Code05 is offline   Reply With Quote
Old 09-14-2011, 08:18 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
That has got to be one of the stupidest stunts on the planet.
Never work live, being a rookie that goes double!!!!
Never try to short out the circuit.
If you got sparks, then the circuit was grounded.
I think your boss needs to give you a few days off to think about how stupid you were!!!!!!!!!
Did I point out how stupid that was?????
Your coworker a real jem also!
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Rob1975 (09-14-2011)
Old 09-14-2011, 08:23 AM   #4
Code05's Avatar
You are being too subtle, tell us how you really feel.
Old 09-14-2011, 08:30 AM   #5
Licensed electrician
Rewards Points: 1,876
Hope your co-workers and friends aren't that lazy. If they are they might not carry your casket.
There are very few reasons to work live, even if you are experienced and have the proper PPE. Changing a receptacle is not one.
Old 09-14-2011, 08:30 AM   #6
Rewards Points: 150
Hey I knew that you guys was going to jump all over me but your not answering the question. I think it's because the grounding conductor was acting as a neutral. Am I right?
Old 09-14-2011, 08:32 AM   #7
Even shorted to the neutral it would not matter. Where do the neutral and grounds connect to in service equipment? What is the purpose of the ground in the event of a fault?
Old 09-14-2011, 08:33 AM   #8
jbfan's Avatar
Rewards Points: 650
Ok, for those that did not quite understand my post.
If you are going to be stupid, and do stupid stuff, I hope that you do not hurt anyone else doing your stupid stuff!!!!!
Old 09-14-2011, 08:35 AM   #9
Just call me Andrew
Rewards Points: 1,020
Nobody wants to go anywhere near answering your question in fear of validating the stupid, stupid stunt you were attempting.
Andrew
secutanudu is offline   Reply With Quote
Old 09-14-2011, 08:51 AM   #10
jbfan's Avatar
Rewards Points: 650
See post 3
Old 09-14-2011, 09:01 AM   #11
Experienced
Jackofall1's Avatar
You have heard it already so I won't harp on it, but the previous posts although abrasive are correct.
The question I have is, when you shorted the line did you indeed get any sparks? You haven't said whether you did or not.
If you did then I would be looking at replacing the breaker.
If you did not get sparks then you didn't ground the circuit (a foolish thing to do intentionally)
Any time line comes in contact with neutral or ground without a load (a dead short) the breaker must trip, if it doesn't then the breaker is faulty.
Mark
Old 09-14-2011, 09:52 AM   #12
Code05's Avatar
Old 09-14-2011, 10:22 AM   #13
Rewards Points: 1,548
A momentary short might not trip the breaker.
Old 09-14-2011, 10:28 AM   #14
Experienced
Jackofall1's Avatar
Given the human reaction time of 1/10 of second and a breaker reaction time of 1.5 cycles, (trip timing of a typical breaker) I am truly doubtfull of your statement.
If the OP shorted the circuit the breaker should have tripped period.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Old 09-14-2011, 10:48 AM   #15
Rewards Points: 150
They are both bonded to the electrode. That's why I think the equipment ground acted as the grounded conductor in that situation
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Amateur Question lda130 HVAC 11 04-17-2009 07:24 AM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
