Aluminum Wiring - Should I Replace It? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-10-2012, 11:34 PM   #16
He asked if he could somehow redo the connections. If he uses the paste and uses the different wire caps, he will have done that. Finished. Done. Pigtailing would make no sense to him, or to any electrician.
All pigtailing does is introduce added and unnecessary connections, without getting rid of the original problem. lol. Why would you introduce more connection points to an electrical circuit? The aluminum doesn't go away. You still need the paste and the special cap. And since you have to remove the device to work on it, "checking it" is nothing more than reading it. lol. If he pigtails everything, that device has to be pulled out anyway. And since the house is at least 40 years old, if he has to replace the devices, for a few bucks each, that is the smart thing to do anyway. What you don't do is pigtail, then nolox and cap, then cram the boxes, just so that you can keep the old devices! No electrician would ever do that or recommend that and no DIYer who knows what he is talking about, would ever recommend that either.
And finally, introducing three extra lengths of 14 gauge copper wire and three more wire caps into boxes that may have additional connections, will make the job extremely difficult to stuff back into the box - if not making it outright illegal. You can't crowd device boxes.
Finally, the stamp on the device will say CO/ALR on the ear if it is designed for aluminum or copper termination.
Newmarket is offline   Reply With Quote
Old 11-10-2012, 11:49 PM   #17
You have NO clue what you are talking about and you prove this with every post.
Pigtailing is by far the best way to remedy the situation without having the re-wire the house.
There are many connection points in a typical circuit. The point that we are talking about is very important since it will completely eliminate the issues with aluminum wiring.
You're right, it doesn't. But the PROBLEM with aluminum wiring (the connection to a device terminal) "goes away".
No, for the third time, you do NOT need "paste".
Why would you have to check it? That is the point that I made from the beginning. It doesn't matter if the device is rating for Al or not since he will be using a copper pigtail.
Replacing the devices is a goo idea, but it is another situation in which he doesn't have to worry about the rating. All typical devices will be rated for his CU pigtails.
Why would someone want to keep the old devices? What are you talking about??
You are the only person here who suggested it
No, for the second time, it will NOT make it illegal nor will it make it "hard". This is an extremely common thing to do, this has been done MILLIONS of times to remedy the millions of devices that have been wired with aluminum branch circuits. No one else has a problem, so i am sure the OP will be fine, even if you can't handle it yourself.
It doesn't matter what the device says, since copper pigtails will work with them all. And, as I stated, this is the perfect time to upgrade to new CU only devices.
Regination is offline   Reply With Quote
Old 11-11-2012, 12:04 AM   #18
I'm sorry I can't help you understand. But I don't need to. I'm addressing the original poster.
You go ahead and pigtail your own house if you like.
Old 11-11-2012, 12:06 AM   #19
And THAT is the problem. It's a shame that people like you are allowed to give bad and dangerous advice
Old 11-11-2012, 12:13 AM   #20
Rewards Points: 528
I definately replaced this AL with copper ..all the way to the box-such a bad connection.
I still see 4 (looks like#6)AL in the neutral bar but all hot to breakers are copper
Is that ok as long as they(AL) are in neutral bar/and correct connector is used for neutral connection.
hidden1 is offline   Reply With Quote
Old 11-11-2012, 12:22 AM   #21
I could go point by point as to why what you just typed so laboriously completely misses the point or makes no sense, but I'd be wasting my time, because you just don't understand what the original poster is trying to ask and you are more concerned with quote-laced rebuttals for reasons of intransigence. I explained it as clear as it can be explained. You don't get it. I'm okay with that.
Old 11-11-2012, 01:04 AM   #22
Master Electrician
Actually pigtailing is the best way to remedy this as alr rated devices are hard to find and very expensive. In addition he will need to put nolux in the copper/aluminum marrette connections and use aluminum rated marrettes. Your both sort of right. The marrettes are about ten bucks a box. The nolux is a code requirement.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 11-11-2012, 01:39 PM   #23
keeping things simple
I edited my original post if anyone is still listening.
Ok... here's a link that has a blurb on pigtailing (4th para):
http://joneakes.com/jons-fixit-datab...cal-connectors
I'll summarize:
There is an organization in the US that says pigtailing is still only a temporary solution unless you connect the copper pigtails to the AL wire with special connector using a special crimping tool operated by a trained professional. A pigtail done this way is basically a "cold weld" and it's the only way to make things permanent and "safe" lol.
Note that the CSA and UL in the US do approve the use of those special marets for copper to AL pigtail connections.
So far the way I see it is I have two options to replacing all the AL wiring:
1. I could pigtail everything and the only worry then would be the copper/AL pigtail connections themselves and of course the over crowded box... all other connections would be copper to brass.
2. I could replace my switches/outlets/fixtures/marets with new AL compatible ones but I still have screw connections where the AL wiring is exposed to oxidation and likely have to deal with this AL wiring problem down the road.
That's what I've come up with so far.
I haven't started anything... still gathering info.
frankm1960 is offline   Reply With Quote
Old 11-11-2012, 02:45 PM   #24
Here's some information from the CPSC in the US.
http://www.cpsc.gov/cpscpub/pubs/516.pdf
They do not recommend the use of marets (twisted pressure connectors) for pigtail connection type repairs. Now I don't know if they're referring to the specialized twisted connectors or just regular marets. Hard to tell.
Any thoughts on this?
Old 11-11-2012, 04:14 PM   #25
Master Electrician
The problem isn't the aluminum. It's connecting of dissimilar metals together that creates the oxidization process. Other than the expanding and contracting properties of aluminum its just as safe as copper. Aluminum won't oxidize if the correct materials are used.
Old 11-11-2012, 04:51 PM   #26
If that's true and the inspection of all my branch circuits reveals that I have all AL compatible light fixtures, connectors, receptacles and switches then there would be no need for me to do anything.
According some material I've read the skin of the wire can oxidize, reducing its electrical conductivity, particularly at a connection from an aluminum wire to a copper wire.
That to me sounds like you can't rule out AL oxidation in spite of using all compatible AL devices. Otherwise they would have said NO oxidation occurs when connecting AL to AL... only when AL is connected to dissimilar metals. Maybe I'm getting to anal on the whole issue.
Old 11-11-2012, 08:40 PM   #27
Rochsolid's Avatar
My home is wired with AL wiring, I did what any smart electrician would do and bought AL to CU marrettes (2.50$ for a pack of 8,do not overly expensive) brought home some scrap wire as penetrox, made pigtails an installed CU devices. A receptacle for AL wiring is like 6 bucks, where as CU receptacles are 98cents a pop. For the amount of money you would spend on AL plugs and switches, your Better off making pigtails just sayin
Rochsolid is offline   Reply With Quote
Old 11-11-2012, 08:58 PM   #28
Check out this link if you got time...
They don't like pigtails with marets, say they're a temporary fix. So I'm a little hesitant. Plus how am I gonna fit all those marets in those little boxes without damaging the existing frail AL wire that's still there? Unless they make bigger boxes?
Old 11-11-2012, 09:22 PM   #29
Rochsolid's Avatar
It's home inspectors that consider it a temporary fix. It is perfectly allowable in both the US and Canada
Old 11-11-2012, 11:22 PM   #30
When I built my house back in the 70s, aluminum wire was all the rage because the price of copper was out of sight!
I used AL wire as it was allowed by code.
A problem ensued at the electrical panel. The fuse terminals were copper and the screws were iron.
These connections failed, and in fact melted the insulation back from the terminals for several inches.
In this case I was forced to use pigtails using CU/AL Marretts.
The switches and receptacles had iron screws also. Although I found no damage, I replaced everything with CU/AL devices.
I still live in the same house, more than 35 years later and have never experienced any more problems.
Aluminum Wiring f.baker Electrical 4 01-12-2012 08:28 AM
Converting Aluminum Wiring to Copper ... njchan Electrical 4 03-14-2010 08:11 PM
Aluminum Wiring House Selena Electrical 4 03-10-2010 10:45 PM
I have a house with aluminum wiring should I pigtail every outlet guyblue Electrical 19 01-28-2009 08:07 PM
exhaust fan wiring question (aluminum wire) sflamedic Electrical 6 01-14-2008 05:41 PM
