Aluminum Wiring House - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2010, 09:38 AM   #1
How can I change outlets for aluminum wiring house?
Selena is offline   Reply With Quote
Old 03-10-2010, 10:04 AM   #2
The outlets MUST be labeled to be used with AL
Do not use an outlet that is only marked for copper - CU
Old 03-10-2010, 10:07 AM   #3
Master Electrician
Rewards Points: 3,760
Receps must be approved for Al use. Al wiring is more fragile than Cu. Are you sure it's Al and not tinned Cu?
If you must mess with this I would recommend pigtailing copper conductors to the Al with specially listed Al/Cu wire nuts. Standard devices can then be used.
When was the house built?
brric is offline   Reply With Quote
Old 03-10-2010, 08:24 PM   #4
Electrical Contractor
kbsparky's Avatar
The proper labeling you are referring to is: CO/ALR.
-KB
Old 03-10-2010, 10:45 PM   #5
Also note that (as far as I know...) no manufacturer makes a GFCI that is Copper/Aluminum rated. To install a GFCI you would be required to pigtail.
brich is offline   Reply With Quote
House electrical wiring issue. gnidaerd General DIY Discussions 5 06-07-2009 03:42 AM
Asbestos concern when wiring old house fw2007 Electrical 46 05-02-2008 10:23 PM
House Wiring Help please FwuffyTheBunny Electrical 1 07-12-2007 11:46 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
