Aluminum Wiring House
2K views 4 replies 5 participants last post by  brich
How can I change outlets for aluminum wiring house?
Receps must be approved for Al use. Al wiring is more fragile than Cu. Are you sure it's Al and not tinned Cu?
If you must mess with this I would recommend pigtailing copper conductors to the Al with specially listed Al/Cu wire nuts. Standard devices can then be used.
When was the house built?
