Aluminum Wiring/Copper Ground? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 09:12 PM   #1
"Old" Newbie
Rewards Points: 177
Our house was built back in the day when aluminum wiring was standard for household outlets. We have since replaced most, if not all, of the wiring with code spec copper wiring installed by licensed electricians.
The question is: When aluminum wire was being used, were the ground wires also aluminum? Always? Sometimes? Never?
I have one outlet that clearly shows a copper ground wire and if I don't have to I'd rather not shut off the electricity to pull the receptical and check the negative and positive wires. Not a big job for sure, but if I don't have to, I'd rather not.
Thanks,
Rob
RCrosby257 is offline   Reply With Quote
Old 06-18-2012, 09:23 PM   #2
Rewards Points: 324
no copper with alu.they did have copper clad used in mobile homes.
oleguy74 is offline   Reply With Quote
Old 06-18-2012, 09:28 PM   #3
"Old" Newbie
Rewards Points: 177
Alum. Wire/Copper Ground
So, my copper ground wire (stick construction, tradional house, NOT trailer) means copper wiring?!
Thanks, oleguy.
Old 06-18-2012, 09:40 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Thanks, oleguy.
No. It could be copper clad (plated) aluminum.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-19-2012, 08:20 AM   #5
"Old" Newbie
Rewards Points: 177
O.K. I'll shut 'er down, pull it out, and know for sure.
Thanks, both.
Rob
How does grounding work? scyarch Electrical 44 06-12-2012 05:59 PM
Bosch 11245EVS Rotary Hammer Drill for Ground Rods tedallen Tools 0 06-02-2012 05:52 PM
Adding a ground wire to a fixture? dkeith Electrical 2 06-01-2011 09:08 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 07:49 AM
