Aluminum Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 10:39 AM   #1
Aluminum Wiring
I would like to change the outlets and switches in my house. I have aluminum wiring and was told by someone at Lowe's that I can use the regular copper outlets, but that I need to use an antioxidant agent. Is this accurate information? If so, is this something I need to re-apply every so often?
ami0007 is offline   Reply With Quote
Old 10-19-2010, 10:52 AM   #2
joed's Avatar
Rewards Points: 12,002
Another idiot who think he knows electrical. You MUST use receptacles the are rated AL and the anti oxident.
Old 10-19-2010, 11:02 AM   #3
Rewards Points: 80
You use AL rated devices or pigtail copper to the AL and use the correct wire nuts. The purple ones with the antioxidant already filled into the wire nut. I believe the part number for the wire nuts is 30-365. Ideal. They are listed for AL/CU connection.
Old 10-19-2010, 11:44 AM   #4
Thank you so much. I had my doubts, but glad I double checked.
The Wife said, "The lights are flickering." Dimmer on aluminum wiring Law911 Electrical 4 03-26-2010 12:19 PM
Converting Aluminum Wiring to Copper ... njchan Electrical 4 03-14-2010 08:11 PM
adding copper pigtails to my aluminum wiring was worth it ntomlin Electrical 7 03-02-2009 12:20 PM
aluminum wiring in homes mcvane Electrical 9 02-03-2008 11:40 AM
Aluminum Wiring! This sucks. Leenders Electrical 4 05-22-2006 09:44 PM
